MODEL IS NXW10QC32G
Reset
volume up and hit power button hold for 5 to 10 seconds then the screen should turn off
now you have a very simple menu on the top sections
of five lines or so
reboot now
apply update ex
apply update from cache
you have to use the olume button to scroll with to get to the line you need
wipe delete factory reset then hit the power button to start
choose the last wipe answer the questions to get to the wipe delete
delete all used data scroll to yes
it says to reboot so
then reboot by hitting power button it will restart with new factory settings
these are known issues with getting hot make sure you purchase a power cord as they tend to go bad just saying .. i hope this helps..
Couldn't get this to work on my nextbook nxw10qc32g, (The cool windows 8.1 10 inch tablet from walmart for $179.)
hold the volume up and and while holding that hit the power button for about 10 seconds the screen will come on and then go off again it will bring you to a menu now you have a very simple menu on the top sections of five lines or so reboot now apply update ex apply update from cache you have to use the olume button to scroll with to get to the line you need wipe delete factory reset then hit the power button to start choose the last wipe answer the questions to get to the wipe delete delete all used data scroll to yes it says to reboot so then reboot by hitting power button it will restart with new factory settings these are known issues with getting hot make sure you purchase a power cord as they tend to go bad just saying .. i hope this helps..
sorry my laptoop scroller got this goofed after the black screen with five lines appears select the one to wipe delete all data.. answer the questions until you can reboot.. this should help you through this on a restore or reset
when you hold the volume up button and hit the ppower button hold them both for about 10 seconds until the screen shuts off turns on and then goes to the black screen with 5 lines on it .. just to be certain you understand what i am saying it works
have you been able to get to the black screen with the lines that allow you to choose to do a reset? if not you have to hold the volume up button and press the power on button and hold it until the opening screens goes black about 7 seconds then you can release the power button and it will display a menu select the one that is for reset factory by using the volume down button.. once you select that then hit the power button to reboot. it should restart with a new factory restored boot
I will check to see if I can find a video for this but this should work for all tablets.
if this is a new nextbook and a password issue and you own it you are best to call the manufacture of the nextbook for password issues. there is no way around this sort of issue it is for protection from people stealing computers and trying to resell them. or obtaining information that is not theirs. if it is in fact yours and you can validate this with proof of purchase the fastest way around a password error is validate it is in fact yours and call the manufacture supply them with the proof they require to validate ownership and they will assist other than the factory reset which should work there is no other way past this issue if it was set up to protect information I may be missing understanding the need for a factory reset but usually this process works.
Hi Linda, Thank you for all the additional info. Sorry that I did not explain what isn't happening better,
oops, entered too soon.. Continuing. Here is what I'm doing. From the table off, I am pressing the volume + and holding. Then I press the power on and hold. 5-10 seconds later I get the windows welcome screen, (the one I get with a normal start up)
Sorry again, but I keep hitting enter before I'm finished.... Think I am doing what you suggest, Expected to see the simple menu, but keep getting to the windows screen with the time and date.
yes the opening screen and then it should turn to a black screen when that happens you need to release the power button it should give you a menu of five or so lines which you will use the volume down button to select on line then hit the power button to reboot ..here is a video I found maybe you are as I am and need visual to see what is to be donehttps://www.youtube.com/watch?v=TyRkUkGd... good luck and keep me posted other than this all i can suggest is call tech support
Thank you again, still not getting to that menu on my nxw10qc32g nextbook 10inch windows 8.1 tablet. Luckily I don't need a solution at the moment, wanted to know how to get the the reset menu without loading windows and going through pc settings in case windows OS got corrupted....
SOURCE: Is there a way to
Yes : boot from the recovery partition (you'll need to give the boot process some more time to keep the choice of the bboting partition displayed :
Windows+Pause, Advanced, 3rd "Parameters" button, change to 10 seconds.)
SOURCE: forgot my password pattern on
Forgot my password pattern how can I reset it back to factory for I will be able to use it
taking the battery out will do it
SOURCE: want to reset to factory settings
This option will typically be under
Settings > Storage > Factory Reset
Acer A510 Tablet, Forgot Password - This is from a Acer Tech and it works for this Model, good chance its the same for most Acer Tablets.
While OFF, Hold the POWER ON button in while also Holding the VOLUME BUTTON down at the same time and then slide the SCREEN ROTATION LOCK BUTTON back and forth about 20 times, then let go off all buttons and wait about a minute, don't touch anything during this period, it will then come back on, now is a good time to go to settings and
