Question about Microsoft Xbox 360 Console
Wazim (exbox)
My ex box would be playing ok for about five minuet, on my tv it would say unavailability signal. I would then try to turn it off and it would not turn off, so I would have to un pluge it from the power source. Can u please help me.
  • 4,402 Answers
Re: wazim (exbox)
No red lights, no previous error msgs, and video output on the box has just died. playing halo yesterday and mid-game the colours went askew (like a green overlay) with horizontal banding, backing out to the dash solved nothing so after a reboot there was simply no video. troubleshooted the tv and cables and its definately the box.
Posted on Dec 12, 2007
0 characters
3 Points
Why won't my wii console power up when I plug it in to a power source?
Ok. Sometimes there is a problem in the power brick. This is the little box on the cable that connects to the wii console. Here's the trick to try to reset it: First, unplug the cable from both the wii and the wall outlet. Leave it unplugged for at least 30 minutes. Then, proceed to plug it back into the wii and then plug it into the power outlet. If the trick doesn't work and your wii still won't power on, you may need a replacement power supply for it. I have added an Amazon link. Hope this helps you out!
Jun 07, 2014 | Nintendo Wii Console
We have been playing wii for months just fine. now wii will not turn off and shows "no signal" i have to unplug it to turn it off. i tried AC adapter trick i even swapped it out with a different one
You can press and hold the power button on the Wii for 10 seconds, and if that does not fix it, try and open up the console and reset the system. Here is a video to help you take it apart:
Thanks, Yomanwazzap
Apr 13, 2014 | Nintendo Wii Video Game Consoles
The exbox error 71 comes up when I turn on my exbox it will not load updates after that it freezes
Here's a tutorial on how to fix it.
Jan 28, 2011 | Microsoft Xbox 360 Console
I recently went online to play and now i get 'no signal' on my tv from the ps3.
ok have you set up the ps3 on the same as the tv wants to go to
ex. hdmi tv + hdmi ps3 = hdmi cable
or if you have it through scart check it on there
and if that doesnt work then press and hold the on/off button for 5 seconds or untill it beeps when turning on your ps3 and it should work with the cable you have connected to the tv enjoy
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
Exbox 360 wont read my game help!!
You need to either clean the laser and try again, and if that doesn't help you need to replace the laser. Sometimes it's just that hair or fibers get in the dvd drive motor and it won't spin. Try unplugging it and plugging it back in and try it, it just might work.
Feb 16, 2010 | Microsoft Xbox 360 Console
My x box will not play through my rca projection tv it was working 2 weeks ago i unhooked it because my vizio tv had to be repaired now i can't get the tv to recognize it. i've tried all the different...
yes, you will have to set up and assign the aux channel thru the tv menu.. make sure that the xbox is
turned on so that the tv will pick up the signal..
Nov 10, 2009 | Microsoft Xbox 360 Elite Console
Scrathing disks
You should try leaving the console flat while playing, if you haven't done that already. Keep it in a spot where it will receive no disturbance from outside sources. Another cause could be due to over usage. Limit the amount of hours spent playing.
Jun 10, 2009 | Microsoft Xbox 360 Console
Exbox live connection
problem is my ex box will freeze up
Feb 06, 2008 | Microsoft Xbox 360 Console
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Martin Murray
Are you a Microsoft Video Game Console Expert? Answer questions, earn points and help others
