Question about Amphion Mediaworks M-270 Portable DVD Player
No pic dvd turns but no pic
0 characters
1 Points
The DVD player is playing the DVD, but the screen is black. I know it has something to do with Line In / Out, but can't remember. Thanks.
I dont know this model but looks like you have it set to output to an external source, Sometimes theres a switch which says in/out which you need to set to in but if it needs to be set in the menuyou could connect to a tv via the line out and once you have the pic up then do the shange on the menu.
The other possibility is there is a little button that becomes depressed when the screen is shut down to turn of the pic when the unit is closed, these sometimes stick. should be easy to spot and worth a look just in case.
Dec 02, 2009 | Initial IDM-830 Portable DVD Player with...
No sound from my DMR-ES40 Panasonic dvd recorder.
Make sure the scart lead is fully in on the tv and the dvd,this can cause pic no sound or sound no pic
Aug 30, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Main screen has no picture
go to you`r pics and change wich pic you want.
Jun 27, 2009 | Durabrand DUR7 Portable DVD Player
Audio not working
Normally it is the scart lead not in properly or faulty.Your normally get pic no sound or sound no pic.I hope this helps.
Mar 01, 2009 | Samsung DVD-R155
Dvd portable
OK...all you have to do is to change the flex cable which is connected from the mother board to the screen or LCD of your portable DVD..i am the is the problem of your Portable DVD.
Nov 13, 2008 | Protron PDV-288 7" LCD Portable DVD Player
Novice installing HDTV(Samsung),DVD(Sony) no pic on TV
Purchased a newer HDMI DVD player,(Sony)as well as found that I do need the video cables.Also found that I need to change the input to component on the DVD player by using a regular coxial to at least get a display from the DVD player had I kept the older one.
Oct 08, 2008 | DVD & Blu-Ray Players
Cant turn off progressive scan
Press OPEN/CLOSE on the DVD player
to open the disc tray.
Press numeric keypad ‘1’ on the
remote control for few seconds.
➜ The DVD blue background screen
will appear on the TV.
Aug 24, 2008 | Philips DVD 622 DVD Player
Black pic on tv fm dvd rec
Several possibilities. If there is a HD box going into this unit, it will give you this message. If there is a modulator or converter box between the cable/sat box and this unit, it will give you that msg. If you have an input plugged into an input, it will give you this msg. Finally, if you have anything other than a camcorder plugged into the FRONT of this unit, it will give you this message. Recheck your connections.
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Progressive scan
Without disc on the tray turn on the dvd then push the stop button for 5 seconds.Good luck.
May 27, 2008 | Protron PD-800 DVD Player
Amphion Mediaworks M-270 Portable DVD Player Logo
12 people viewed this question
Top Amphion Mediaworks DVD & Blu-Ray Players Experts
Are you an Amphion Mediaworks DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
