Question about Lite On (ldw811s) DVD±RW Burner
Liteon dvdburner cant download nero7 says errors --missing
  • 51 Answers
Re: liteon dvdburner - Lite On (ldw811s) DVD±RW Burner CD & DVD Burners
Off our meds this evening, granny?
Posted on Nov 12, 2007
0 characters
3 Points
Do they have GCE-8481B105 DVDBURNER SOFTWARE?
Most devices have firmware update.
Check your device product website.
Be careful while updating or you might get a fatal error!
Jun 05, 2014 | LG GCE 8481B CD-RW Burner
Media player classic says "cant find dvd directory" when i put in a movie dvd?
try downloading VLC player
It is free, and it plays almost every video format
Nov 14, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
I also get error 2131 on Samsung R70 laptop - PLEASE HELP ARRGHH!
It seems that its a NEC Itunes issue and i itunes dont seem to want 2 know..sorry cant help you more
Sep 06, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Write error message with liteon dvd writer..
I had the same issue with a liteon DVD drive I had. It worked fine and then one day it couldn't write to a DVD if I paid it to. I troubleshooted it for a few days, installed all the latest updates and patches and still nothing. From what I could tell, it baiscally died. So fortunately Liteons are relatively cheap so I just went out and got another LiteOn and it worked just fine. I would consider purchasing a new Drive.
May 04, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Need Driver For Liteon LTN 5268
Usually Techspot is a great resource! You can download the firmware from the following url:
Mar 19, 2009 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
LITEON LVW 5001 doesnt recognize DVD's
Laser either dirty or starting to go.Try cleaning laser with commerical disc cleaner,put a drop of rubbing alcohol on brushing.Laser can be cleaned manually with a Q tip dipped in rubbing alcohol but this requires opening burner.If you do this MAKE CERTAIN ELECTRICAL PLUG IS PULLED,lasers cause nasty burns.
Some times the problem is just the brand of disc,some brands don''t work in Liteon's.
If laser is going the burner can be replaced.Most of the Liteon 5001's used Liteon 401s burners,411s or 451s dvd burners all will work.The dvd burners mount from the bottom PC burners mount from the side so they would have to be adapted,many PC burners won't work in these older liteons some freeze up the second you hit fast forward.
Jan 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
Burner will not read DVD
hi there start by removing the current drivers and then you can make shure that you dvdburner is set up as master or slave then you can make shure that the ide wire is pushed in all the way then reboot let windows load the drivers for it and away you go good luck
Jul 13, 2008 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
need to ask acer go to ask if it is compatable>on help or I say by my own trail and error that if it fits
in the place where the orther one was it will work (just make sure that it fits the same as the one you took out ... lala linda
Jan 09, 2008 | Acer CD & DVD Burners
Can't burn I-Tunes downloads to CD on my new rewriter
the retailer is correct, you can only play the tunes that you have downloaded on the one pc and an ipod because of the licenses that are downloaded with the songs.
Oct 25, 2007 | Lite On LiteOn LH-20A1P - Disk drive -...
Open Questions:
Lite On (ldw811s) DVD±RW Burner Logo
61 people viewed this question
Top Lite On CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Are you a Lite On CD and DVD Burner Expert? Answer questions, earn points and help others
