Question about Samsung SyncMaster 940MW 19 in. LCD Television
Need the adapter for the non standard cable connector on the back of 940mw
The cable connection on the back is a screw on connector that has a female center . this connector compared to the standard usa 75 ohm connector is huge. i need an adapter for it. no one in colorado springs seems to know what i am talking about.
    Brigadier General:
  • 6,966 Answers
Your Samsung SM940MW supports multiple TV and video signal formats including NTSC, PAL, and SECAM making it multi-system.
The aerial/cable input follows the European standards. What you described as "screw on connector that has a female center" is better known as a "PAL" connector whereas the US uses the "FP". What you need then is a female FP-5 to male PAL adapter.
This page would list most of the common adapters for such a purpose. Perhaps you can print it out and show to the salesperson when you go looking for one.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 12, 2007
  • Louie  Role
    Louie Role Nov 15, 2007
    Hi again,
    Please find below image of a PAL to F adapter that might work for you.
I moved the Mintek Tv from my bedroom to the living room, the tv cable cord will not screw into the Tv, I was told that I need a adapter, coax to av-rca, is this correct? What do you think?
Not sure due to lack of information to go on
I. think you need a tv coaxial female to f plug male adapter
really depends on the TV cable cord what is the gender of the end of the cable if it is coaxial male then the adapter needs a female coxial
if the tv has a female socket hole then the f type part of adapter needs to be a male.
The tv manual may shed some more info on the type of RF antenna coaxial connector. it uses.
RCA can be confused as av is to do with with hooking up a Video recorder with Video output being the yellow plug and audio with Red and white plugs.
I think you need a RF coaxial adapter rather than AV RCA if you are connecting tv to a tv antenna or tv antenna splitter device.
there is a RCA standard that has adapter like below link
again gender types are needed to be considered before deciding if correct type of adapter..
You could research the rca rf standard to see if it is used in your country. My country uses Pal coaxial standard.
May 03, 2015 | Mintek Televison & Video
How do I connect the coaxial cable?
This is quite simple. Your wall box is a male connector. The TV input is a female one. Make a cable with resp; female and a male connector. Unless the wall box has a 'screw on' connector. (FC10 f.i.) Then you need this special item and/or crimp tools in order to fit this FC type connector to the coax cable. Not simple.
Oct 12, 2014 | Televison & Video
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
More information on the DVI connector styles, and the Digital Visual Interface technology,
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Jul 16, 2011 | Computers & Internet
Changing cable port
The monitor is a Fujitsu VL-15DX5G. 15 inch LCD.
The monitor cable uses a female DFP20 connector.
(Display Port 20-pin)
So you need a male DFP20 to male DVI-D adapter, or adapter cable.
DFP20 Male to plug into the monitor cable, and Male DVI-D (Dual) to plug into the graphics card's, female DVI-D connection.
So far, all I have found from a quick search is a Male DFP20 to Female DVI-D adapter, such as this example,
Of course this won't do.
IF, this is all that's available for DFP20 adapters, you'll need an adapter of Male DVI-D to Male DVI-D, also. (Yes, I am aware of how crazy that sounds)
(It would appear, adapters are sold to connect a normal DVI-D monitor cable, {Male}, to a computer with a female DFP20 connector)
Should your searching only find DVI-D female to DFP20 male adapters, or adapter cables, then here is an example of a DVI-D male to DVI-D male adapter,
(DVI-D male to DVI-D male cable would probably be better as there would be less strain on the graphics card's DVI-D connection)
May 14, 2010 | Computers & Internet
Can you connect earphones to this TV? -GE25GT240 Serial #943516018
There is no front panel earphone jack for this TV. From the owners manual I can't find the rear view of this television. If there are connections on the back for AUDIO OUT there will be two connections for an RCA type connector. All you need to do is to get an adapter (from Radio Shack) and plug that into the two Audio Out connectors on the back of your television and plug your headphones into that adapter.
I recommend this one:
If you have a 1/4 headphone connector (the old type) you can convert the 1/8 to 1/4 inch with this one.
Apr 16, 2010 | GE 25GT240 25" TV
The female cable connector on the back of the tv broke off
yes,you could also use RCA cords from the cable box to the tv and bypass that by selecting the video channel that you hook the rca's to
Jun 02, 2009 | RCA TruFlat 27F520T 27" TV
Cable in connection
Most TV models/cable providers uses the F type of coaxial connector as shown below. 7c21c7e.jpg
However, some versions intended for other regions (Europe & Middle East) uses the PAL type of connector likewise shown below.
If your model uses the latter and your cable provider uses the F type, what you need is a straight F type Female to PAL Male adapter. Or it could even be just the other way around.
They are available in most electronic parts/supply store or online. You can try here, here or here.
Hope that this be of idea/help. Pls post back how things turned up, r should you need additional information and/or if your cable connectors are of different types. A photo of the connectors would be nice.
Jan 06, 2008 | iLO 3200 32 in. LCD Television
Samsung SyncMaster 940MW 19 in. LCD Television Logo
105 people viewed this question
Jerry Greenberg
Jerry Greenberg
