Question about GE Spacemaker JVM1640SJ Microwave Oven
Turntable does not work
The turntable stopped working, but everything else is fine. When I try to set the turntable to on, it bounces back to off.
  • 473 Answers
Re: turntable does not work
Need to check if you have power to the turntable motor. Either is has a bad motor or a bad relay on the control board.
Posted on Nov 12, 2007
  • GE Master
  • 8,795 Answers
Does the display change from turntable on to off or is the turntable just stopping?
If it's changing in the dislay, the turntable key on the keypad may be a bit bouncy. Try pressing it quickly to see if it stays on.
Otherwise it may be as fridgetech sayeth.
Posted on Nov 26, 2007
0 characters
3 Points
Glass plate does not rotate
Here are a couple videos that show you how to replace the turntable motor and diagnose
Feb 10, 2015 | Panasonic Microwave Ovens
Turntable does not turn
Possible that the belt has failed, or the motor is not working or that there is no power from the control panel to the motor.
You need to remove the bottom panel to observe this and confirm.
Feb 11, 2013 | Microwave Ovens
Turntable stopped rotating. Everything else works fine.
It sounds like the turntable motor has failed. It is a synchronus motor with a plastic gearbox reducing the RPM to about 5. The gears fail when the turntable dish is turned as the motor stalls the shafts.
Replacing the motor is no big deal.
There is usually an inspection cover that can be removed on the underside of the cavity.
Remove the cover and remove the motor.
Replace with the same type and the reverse procedure will fix it.
You may however require a self tapping screw to affix the cover back on. A bit of a puzzle but not too difficult to work out!
Hope this helps.
Nov 29, 2010 | Whirlpool MT4155SP Microwave Oven
Microwave turntable doesn't turn. Everything else
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find links to helpful exploded view diagrams and part ordering help here.
But if you've recently had trouble with the cooktop lights, then the control board may be damaged.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Nov 28, 2009 | Frigidaire Microwave Ovens
Grill element stopped working.
I had the same. Dismantle the oven and see at the back side the connection wires for the heat element. Mostly one of the connectors is faulty. I fixed it that way.
Jul 29, 2009 | AEG MCC663 Microwave Oven
The table in our GE JVM1630 has stopped turning. Everything else is working just fine. Any suggestions.
Check the turntable motor by giving direct supply to it. If it is not working you have to replace the motor.
Jul 07, 2009 | Microwave Ovens
My turntable stopped rotating on my GEJVM1490 for no reason. everything else works fine, any suggestions?
There is a small motor underneath the microwave which turns the plate or turntable around.
If this is faulty then you will need a service agent to repair it.
Jun 17, 2009 | GE JVM1440 Microwave Oven
Please reply back with your brand and model number so we can help you.
Jan 07, 2009 | Maytag MMV5156AAS Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
This is just a preliminary reply. We will need more information to help you.
So you're saying you can set the cooking time but when you press Start it won't start?
If this is the case, you probably have a bad door swithc or door switch mount.
Please reply back with more detail so we can help you.
Dec 07, 2007 | Frigidaire FMV156D Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,061 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
