Question about Ricoh Aficio 1022 All-In-One Laser Printer
I have a RICOH Aficio 1022 photo state machine. Having a problem from last 2,3 days, and the following message showing on the screen: "Functional Problem within the machine. Turn main power switch of
Same as above question.
    Sergeant:
  • Ricoh Expert
  • 229 Answers
Firmware installed
Posted on Dec 24, 2014
SOURCE:
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Functional problem sc 541 for richo aficio 1022 photocopier
SC541 = The melting temperature measured by thermistor is less than 71 C
The problem lies in the fuser:
- Thermistor fuser defective or incorrectly installed
- Fuser Lamp failure
Solution: Replace Fuser
Jan 05, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Reset photoconductor units aficio 410dn
www.ricohpr.com/.../Ricoh%20Aficio%20SP%20C410DN%20LTR%20%5B34245%5D... -
in order to reach the Ricoh restore factory menu, you need following steps.
1. push the yellow small "C" buttom. you can hear beep.
2. push the 3 numeric buttoms, in following order: 1,0, 7 .
3. push the big red "C" buttom, don't release for 5 minutes until you saw a copy windows popup on the screen.
choose the "copy sp", then trun off the power, and turn it on again.
now done, you have reseted the factory settings for the Ricoh Aficio munti-functional copier;printer.
If you really need the actual "Chip" then you will have to get a Service manual, inside there are circuit diagrams and circuit details.
May 06, 2010 | Ricoh Aficio SP C410DN Laser Printer
Functional problem with the copier (Savin 2545) Service Code SC 546
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
May 29, 2009 | Ricoh Aficio 450 Copier
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
On lcd massage
some times the nipple (cover) of the toner stays in the toner holder this wont allow the new one to be opened
Sep 22, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
The function key
hi whats the SC code showing up?
May 27, 2008 | Ricoh Aficio 250 Copier
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 1022 All-In-One Laser Printer Logo
89 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
