The cooling fan at the bottom was not working I replaced that. still not cooling in the fridge
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through
it. There is a flap you adjust with the
fridge temp. control. Make sure it's opening and closing when you adjust the
fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
SOURCE: Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
SOURCE: F&P E402B Active Smart Fridge Compartment not cool
You need to start with a clean totally defrosted unit. That means clean, vacuum and wipe as much as you can around the entire motor compressor area especially any coils you can reach. Then set temp around whatever normal is and see what happens. If still the same it's time to have a tech do pressure tests.
SOURCE: fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
