Question about Refrigerators
Kenmore side by side #50562991
The freezer has completely defrosted and the fridge side is now warm. the fans are blowing but it is not very cold. all the ice has melted in the maker. i cleaned underneath the unit and cleaned the coils off and there is a black pod with copper tubing going in and out of it, there is a switch on the side with a red and white wire going from it to a fan. when i plug the fridge in that switch clicks or the pod clicks and then clicks again. i have never heard this before. it seems that the fridge is running and fans work but no cold air. what can i do.
  • 290 Answers
The black pod is the compressor and the switch on the side is the compressor start relay. You either have a failed relay or a locked up compressor.
Most likely it is a burned out relay.
Unplug the fridge and remove the relay from the compressor.
Shake it. If it sounds like a lot of loose pieces are rattling around in it, it is burned out.
Be sure you replace it with the correct replacement part. A "fit-all" relay may work for a while then cause the compressor to fail.
Your model number has 106 in front of it. You will need to know that when looking up or ordering parts.
Post back if you have any questions.
Posted on Nov 12, 2007
  • Michael  Lindley
    Michael Lindley Nov 14, 2007
    Just wanted to follow up on your fridge and see what you found out.
  • Michael  Lindley
    Michael Lindley Nov 28, 2007
    Just curious to know if you got fridge fixed.
It's a circulation problem so either the fan in the back of the freezer(circulates freezer and blows cold into fridge) or the defrost element. If the element is faulty the rear ices up and air won't flow. If fan is faulty it's not blowing the cold air. Remove rear panel if no ice it's the fan if its full of ice it needs the defrost element(usually get termination sensor also depending on type) If you open the freezer door and hold in the doorswitch you should hear the fan running if its working.
Jul 08, 2013 | Kenmore Ice Maker Kit For Sears Whirlpool...
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore Elite Coldspot side by side Model # 106.57706701 Frdige warm, freezer is frozen up. Have removed back panel several times in ther freezer to defrost coils and several weeks later, same problem.
check the fan that transfers the cold air from the freezer to the fridge. thats where it comes from if you didn't know that. also check the the fan on the condenser at the bottom of the fridge. it should be blowing hot air off the condenser to facilitate the elimination of the heat from the condensing unit, just like your a/c does on the houe.
Jul 20, 2009 | Kenmore Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Side by side freezer works fine ice cold.fridge not so good. only at 57 degrees
Listen for the fan motor to run. Open the freezer\ push the door switch with your finger \ listen for the fan that blows the cold air to the fridge. only the freezer side gets blows cold to the fridge side. If the defrost timer has broken then ice may be blocking the flow of cold air to the fridge also. Only 2 things to check. Good Luck
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
703 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
