Your machine will show 100% and that is correct. It doesn't mean memory full, but rather the amount of memory that is still available. Once you scan a document you will see the memory drop down to 99% or even lower depending on the size of the scan. If you don't see this happening than you are not scanning. Other than that your scan will either go to a folder on your PC or straight to your email. All you need to do is locate the folder it saves your scan in (usually created in your C: drive) or check your email folders including your Spam/Junk mail folders.
verify that the paper size shown on the display matches the size and direction of the paper in the respective trays, make sure paper side guides and rear backstop are tight against paper
if u mean the size of image is reduced, as i know, the resolution of image, dpi, is too small --> try bigger dpi if u mean the image is cut off, u have to clear the scan area or by default
There are a few ways, such as configuring "SMB", "Scan to "Email" and/or installing "Scanrouter", but they are too involved to explain here. The other is the "Network Twain Scanner" which, once installed, you can use a program such as "photoshop" , or many other photo editing softwares to scan. Simply open the program, click "file", "Import" and you should see the scanner as an option, make your settings, and go. You can get the software here. Just select your operating system. It will need to be installed on each PC:
Using SCAN feature of Paper Port software - (after clicking SCAN button ... select Define under Options section of the window ... the option to select paper size then exists). With harmony.
We have also seen that Adobe Acrobat doesn't produce very clear scans (with a range of scanners). Adobe gives very good pdf file size but it downsamples images.
Dear David,
I bought a second hand IS420 on ebay, and bought a service manual at: www.electronicsrepair.net/scan.shtml
See #86
You can buy it for $10.
Good luck,
Brad
