Question about Pentax Optio S50 Digital Camera
Flash Whenever I take a picture, no matter what mode it's set to, the flash will not turn off. I looked through the manual and found nothing. How do you turn flash OFF?
    Problem Solver:
  • 9 Answers
Where the OK button is there is a circle around it. On the left side there is a pic of a flash. You have to turn on camera then turn off flash by pressing the button on the left (flash) til your display shows a flash with a circle around it in the top left corner. Now the flash will not come on.
Posted on Apr 21, 2008
Will not take a picture with flash
this URL is for the manual for your camera Page 28 explains how to toggle the flash on and off in different modes. It is easy and the explanation is short and clear. It is preferable to use a flash for fill light almost all the time so these modes are really great. However if you are in a low light setting you don't want the flash or you will get the 'snapshot' flash look. Try holding camera very steady and keeping the subject from moving too much and shoot without the flash. Once you get the hang of turning the flash on and off you won't hardly even need to look to do it....
Jan 06, 2014 | FUJIFILM FinePix AV100 Digital Camera
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
May 12, 2011 | Samsung S860 Digital Camera
I have a problem with my canon sd850 is. It can
You should be able to set the flash to off, auto, auto with redeye, slow-shutter sync, and forced flash on. The last two should give you the results you're looking for. If these aren't available in manual mode, get out of manual mode.
Nov 22, 2009 | Cameras
Flash does not fire.
In auto If it does not fire the flash bulb or flash board in camera will need service. In auto it will fire all the time as a fill flash.
Jun 14, 2009 | Canon PowerShot A700 Digital Camera
The flash will not work on my Samsung S860 Digital Camera. It used to work and now it doesn't... I tried to go through the menu to fix it and it seems to say it is on? But, when you take a picture it does...
the S860 has three flash modes in which the flash only fires under certain conditions.
- in Auto Flash mode and Auto & Red Eye Reduction mode, the flash will only fire if the subject or background is dark; otherwise it won't flash.
- in Slow Synchro mode, the flash only fires when the camera's using a slow shutter speed.
if you have your flash mode set to any of these, the flash will only fire when the camera determines that flash is needed; otherwise it won't fire. to have the flash fire all the time and automatically vary its intensity according to how much light is needed, set the flash mode to Fill flash; to turn the flash off altogether (so that it won't fire no matter what), set the flash mode to Flash Off.
for all the details on the S860's flash modes, you can download the user manual here and refer to pages 28 and 29.
hope this helps...
Mar 08, 2009 | Samsung S860 Digital Camera
Nikon D100 Manual shooting help
The mode dial (topside left) must be set to M. That's it for manual settings - the camera won't check anything, and certainly shouldn't require the flash. You need to choose your own shutter speed and aperture settings to get a good photo, but the camera will let you take a picture no matter how you have it set.
Feb 01, 2009 | Nikon D100 Digital Camera
No flash
hey folks, i had the same issue, i was sooo annoyed. I looked in the dinky manual and found nothing. Turn your camera on with the lens cover closed. Hit Home, select the briefcase bottom right hand corner. select MAIN settings and hit OK. Select initialize, this will restore the camera to factory default values. Bringing back the flash. Don't ask me why it disappears after awhile. I thought i was going mental and m friends all thought i was an idiot. hope this helps.
Jan 03, 2009 | Sony DSC-T70 Digital Camera
Slow taking pic, flash flashes multiple times while lenses acts like it is trying to focus
The evolt cameras use the flash bursts as a "autofocus help". Try to find points with high contrast or edges to point one of the three autofocus points at (you see these points while looking through the viewfinder and they flash red as soon as the camera is focused).
So, flash bursts basically mean "too low light" some other situation which is hard for the camera to focus. In such situations, try to switch to MF mode (manual focus). Or you could buy an external flash (e.g. Olympus FL-36) which has a red light for autofocus assistance instead of flash bursts.
Dec 05, 2007 | Olympus EVOLT E-500 Digital Camera
Why do my pictures look too dark?
You may need to use the flash. Make sure the setting is not flash off. If you're using the flash, make sure your subject is within the range of 14 feet for wide angle shots or 11 feet for telephoto shots. Use Image Expert to adjust the picture's brightness and contrast. Try adjusting the camera's exposure or sensitivity settings (use the Manual user mode). If you're taking pictures in the Manual user mode, look for the EV! warning that appears on your LCD screen when you are taking pictures out of the ideal exposure range. If you have trouble setting both the aperture and shutter speed manually, try adjusting the aperture and letting the camera choose the shutter speed with Aperture Priority mode. If you're using the macro mode to take a close-up photo, be sure to provide adequate lighting for your subject. If you're taking a picture at night and you want to light up the background as well as your subject, use the camera's slow synchronized flash mode. If you need more light, attach an optional external flash to the camera's hot shoe.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Pentax Optio S50 Digital Camera Logo
602 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
