Question about Hitachi 50V500 50 in. HD-Ready LCD Television
The picture has a pink and reddish hue
I need to know how to reinitialize the memory to eliminate this problem for my 50V500 50 inch TV. We have had several repair men come to our house and within 5 minutes the TV is working fine. What are they keying in on the remote to adjust the picture hue? got pink picture  black colors not show
  • 934 Answers
Any magician can make a trick look easy - but NOTHING replaces years of training and experience. That said, here's your answer:
  1. Enter the I2C Service Menu, be sure the power is OFF.
  2. On the front control panel, press and hold the INPUT button. Then press the POWER button for two seconds. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
COPY DOWN THESE SETTINGS:
IMPORTANT: The following are Service Adjustments. These Data Values are lost when Memory Initialization is preformed. It's important to write the values down before proceeding.
H Position: ________
V Position: ________
LCD ADJUST (NOT LCD DRIVE) (Arrow right)
GHOST (Arrow right)> LCD ADJUST =SHP: _______
(Press Select) LCD ADJUST GHOST=R: _______
(Press Select) LCD ADJUST GHOST=G: _______
(Press Select) LCD ADJUST GHOST=B: _______
(Press Select, then Exit)
V COM (Arrow right)> V COM-R: Set For Minimum Flicker
(Press Select) V COM-G: Set For Minimum Flicker
(Press Select) V COM-B: Set For Minimum Flicker
NRSH (Arrow right)> VS-DAT 1 through 9: _______, _______, _______, _______, _______, _______, _______, _______, _______ (Press exit twice)
Scroll down to: “TA1383” then (Arrow right)
Scroll down to:
CONTM1: _______
CONTS1: _______ (Press exit)
After writing down these values, please continue:
Posted on Nov 13, 2007
  • William Rayburn
    William Rayburn Nov 13, 2007
    Scroll up to “MEMORY INTI”
    1. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
    2. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
    3. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
    4. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
    5. Turn the set off-on and Confirm the picture remains in a good condition.
  • William Rayburn
    A tech can do this over and over buth the problem remains... Eventually the board on the light engine will have to be replaced. And the frequency at which the problem keeps happening will increase...
    Please don't kill the messenger
    and Good Luck!
    Bill
I bought a new vivitar vivicam t324n digital camera. I used an SD card that I had previously used in my old vivitar vivicam3935. All the pictures have a reddish hue. When I called vivitar the 1st time they...
There is a function in your camera setup menu to format memory cards. It won't make any difference to the reddish hue of the pictures, but it will delete everything on the card.
No, you can use any SD card, and in fact you are using the card you have. Your camera can take and display pictures, so it is using already. These cards are digital- they either work or they don't. You might get a corrupted picture file but a memory fault wouldn't just add a hue to all shots like a film might.
It won't hurt to get a new card and try it- then you can tell them that you did what they said and it didn't help. The card will be of use as a spare or to hold more shots on holiday. At some point you need to return this camera as it seems to have a fault, but it sounds like they are trying to blame the old card instead of giving you a replacement or repair.
Dec 01, 2010 | Vivitar Cameras
Fuji Finepix V10 Red Pink Hue in pictures and on LCD
Sounds like the sensor ribbon has slightly come out of it's socket.
Just needs re seating
Jan 24, 2010 | Fuji FinePix V10 Digital Camera
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Pink hue
Remove speaker grill, manually adjust red drive untill red is normal.
Sep 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Vizio 37" LCD color problem!
is the TV still under warranty. if it is I would call Vizio and request a main board be switch and if it is not under warranty I would call a TV Repair shop and have them put in a Main Board.
Mar 04, 2008 | Televison & Video
Tv picture
http://esupport.sony.com/perl/news-item.pl?news_id=24
and try this
Sony Picture tube recall
Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700
Jan 30, 2008 | Sony KP-51WS510 51" Rear Projection...
Samsung 61 inch DLP
Needs color wheel. What's the model #?
Oct 27, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
162 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
