I'm guessing its a window type A/C. First Remove the fron cover of the A/C, its a snap on so you just need to gently. Next is pull out the inner assmbly, the drain pan usually has a handle curve you can pull, be careful not to drop the AC. from there you can clean the unit and declogg the drain by hosing it down.
i have a goodman a/c airhandler outside unit model #pho48-1ab and i need a wiring diagram to...
(More)
i have a goodman a/c airhandler outside unit model #pho48-1ab and i need a wiring diagram to properly connect 2 black relays on the side of the heating element box and i can not read the schematic on the panel
"spillage at draft diverter on wall heater. Should have vent checked" See heater...
(More)
"spillage at draft diverter on wall heater. Should have vent checked" See heater (HVAC)
Written by PG&E
No warning noise. Worked wonderfull. Getting electricity power OK. Stoped working. Dead! Maybe...
(More)
No warning noise. Worked wonderfull. Getting electricity power OK. Stoped working. Dead! Maybe inside fuse failed. What should I do? How do I check?
