Question about RCA D52W19 52" Rear Projection Television
Need help to locate two parts.
I know I have to replace part # 264103 vonv output mod.and # 264104 conv power supply. I was quoted 550.00 to fix,too much for me. Is this something simple to do? If so where would these two parts be, Anyone know of a good part store? Attached to the same board or totally seperate? Can someone point me into the right direction with advice or web site I can use,...many thanks. Never worked on a Tv but upgraded a few computers...
  • 1,030 Answers
The parts are the convergence power supply and convegence amplifier board. two circit boards that are over the main cuircit board. I dont find there too difficult to replace. i believe union electronics carries those. always be carefull in a television. there are voltages that will hurt you.
Posted on Dec 20, 2007
My Samsung UN60f6300afxza tv died suddenly while watching? I am hoping to repair myself. There is no power to the tv. No lights etc. The outlet has power. I'm thinking power supply but im not sure.
you probably could fix it yourself but to do that you have to know what has happened
take it in for a proper diagnosis and a quote then replace those parts that are found to be faulty
from the number of questions of how to fix after wasting money on diy efforts on this site , unless you have experience in electronics , you should consider the cost against the effort of diy
Jul 24, 2016 | Samsung Televison & Video
Screen displays "overload, switch off power." Have
Hi Laurel,
Overload in other unit protect error code. This will appear once the processor sense a malfunction either on the power supply or on the load (high chance is the output IC). DIY steps are as follow to determine where the fault is : 1. Allow the unit to cool down for an hour. Give proper ventilation and keep away all obstruction from the vent to have a sufficient air flow. 2. Disconnect one at a time the speakers, inputs, from the unit while powering it on.
If the unit back to normal again then you've confirmed that any of the above caused the error code. If #1 is the caused, you have to check also the exhaust fan(if installed), clean it as much as possible, replaced if faulty. If #2 is the caused (speaker) check the wire and speakers for short, (input) check the RCA cord for short or replaced if necessary.
If the above simple fix didn't cure the error code, you can try the next steps if you are an electronicsenthusiast. Now after removing the cover, you have to concentrate first on the power supply board. Look for bulged electrolytic capacitor. Leaky capacitor will affect the regulation of the supply and will trigger the error code. Look for dry joints. Check it also in the pre-amplifier stage, main output board where a big heat sink is located. Next disable the output amplifier stage by disconnecting the supply. If the unit come out, make some re-soldering on the board, spot the cold solder and dry joints and then try to connect again. If the error code appear again, high chance that your output IC is faulty but still to be confirmed. Using the disoldering pump and soldering iron pull-out the output IC from the board then try the unit. If the error code disappear, confirmed that your IC is faulty.After trying the abovesteps-by-steps guide and still the symptoms persist this is the time for you to send it to repair shop. Remember that your unit has a lot of parts and only some basic steps have done, leave the expert to troubleshoot the entire unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 24, 2011 | Panasonic SA-HE100 Receiver
Who does in home TV repair have an RCA D61W20 or can it be done m
The most obvious item which is causing your problem are the 220K ohm 1/4 watt resistors on the convergence power supply board. There are four of them RP10, RP11, RP12 amd RP13
Jun 18, 2009 | RCA D61W20 61" Rear Projection Television
It shows a service code of 99
Code 99 leads to a defective power supply !!
A replacement is very expensive ;-(
Arround the € 550,00 / $ 650,00
Try to let repaire the power supply unit.
Best regards , EuroNet 2000 The Netherlands
Apr 19, 2009 | Sony PFM-500A2W 42 in. Television
Mod. WS-655111 Fuse F9A04 & 05 bad. Set goes on & right off
You can order a replacement STK393-110 for this model (62HM95) from a major parts distributor at the link below:
Mitsubishi WS-65511 Replacement Part Convergence IC STK393-110
You would probably have to recalibrate the convergence after you install the IC. There may be a convergence kit available as well.
Apr 10, 2009 | Mitsubishi WS-65869 65" Rear Projection...
I need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Dec 11, 2008 | Music
Keep blow fuse on power supply board, viewsonic vx910
Replacing the fuse twice is OK but going beyond that doesn't make sense.
I don't know where the fuse is located in the circuit, AC input or some output point.
If it is the main AC fuse, the main power supply is probably faulty and one needs some experience to locate the shorted component.
If it is on the output side you have a shorted part and the above admonition applies; you need some training to know what you are looking for.
If the supply is on a separate board as is common, look for a part (assembly) number and do a search to see if there are companies offering repairs on that supply; if not, you may get stuck buying a new one and there is no guarantee that the supply didn't fail for a reason. You could have a 'downstream' problem that killed the supply.
Oct 10, 2008 | ViewSonic VX910 19" LCD Monitor
RCA P52960YX1 power supply dead - can I replace this myself?
Ok, Look, you can do this. Just take care when desolder any electronic part. ( position). mostly in capacitor ( - + location). You can buy a : power supply kit for ctc169 chassis. But maybe don't need replace all parts, just replace 2 small electrolytic capacitor 2.2uf 100v and 39uf 100v and ready...I hope this will help you. Thank you !!
Jul 21, 2008 | RCA P52926 52" Rear Projection Television
Need a Power supply for a LT26HVX Olevia LCD
That is because no one knows how to troubleshoot to the component level anymore in this "lowest repairable unit" world we live in! Throw it away and buy a well know TV set. Another item for the land fill....Shame! Sorry as it is, just a shame.
Former electronics technician - level troubleshooter - US NAVY
May 23, 2008 | Syntax LT26HVE 26 in. HD-Ready LCD...
RCA D52W19 52" Rear Projection Television Logo
76 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
