Question about Ariens 34 In. Zoom Series Riding Mower
I can not find a part number for the belt that turns the blades.Ihave a model 915131zero turn.
    Problem Solver:
  • 5 Answers
On your web page it said the question would be ansered free,next page you wanted 9.95 a month, i do not want this service, your web page is miss leading. thanks
Posted on Jul 07, 2009
SOURCE:
Ihave a craftsman ridding mower model #917.289900 new belt for the deck new blads it still leaves miss cut in the middle anybody know why?
usually if its missing cut it's not rotating fast enough, or the other thing it can be the blades have not been sharpened. some companies that make blades don't sharpen them so they can be handled, it will have a leading edge and you need a sharpening stone to put a cutting edge on the blade. and the blade has to be put in the right way round. flate top cutting edge bottom.
Jun 14, 2017 | Craftsman Garden
I have a 17.5 HP Yard Machines,8 speed shift on the go, 42'deck. Worked fine last year, The year, blades would not turn, engine pulley burned up the belt. Replaced the belt, did not solve the problem.
take the belt off and be sure the pulleys turn freely. sounds like you mowed through water and they may have some rust on them or the bearings in the spindles are bad. just take the belt off, turn the pulleys and find the one that is bad and repair it.
May 21, 2017 | Mtd Garden
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
Why does my mower run slowly?
your spindle bearings are bad,take off the belt and turn each one,the one that doesnt turn freely needs to be replaced
May 02, 2015 | Garden
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
Our indestructible deck has made mowing impossible, it clogs all the time and then "coughs" like it's dying. We have to stop mowing and turn off the blades and turn them on again to shoot the...
Hi and welcome to FixYa I am Kelly.
Maybe I am missing the obvious but I have had a couple of people that had this problem with since new use of a mower. One of them had the wrong blades with the deck and the 2nd one the baldes were installed with the air foil side DOWN. If you have Air-flow problems under your deck the above is possible or your blade deck drive belt is routed incorrectly. The decal for the blade deck belt routing should still be on your deck. Look at the decal drawing vs the actual routing of the deck belt. It is highly possible that one or more of your blades is driving backward.
If you can not find your decal (would be hard not to find it on a deck not 1 year old!), I will try and look it up but I need the model number of mower and the DECK (2 ea model numbers 1 for mower 1 for deck)
Thanks for choosing FixYa,
Kelly
Apr 22, 2011 | Garden
Blade number for Ariens Zero Turn Model 1840. Need
Depending on which version of the 1840 you have and when it was built it could be several blades...
Please get your model and serial number and then enter them into the following site's search engine. You should then be able to identify the parts you need.
http://partsradar.arinet.com/scripts/EmpartISAPI.dll?MF&app=ariens&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer
John
Jan 18, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
The mower blades will not turn. Tractor runs fine but the blades will not turn when the pto is switched on. There is nothing block or holding the blades. They just will no longer rotate when the pto is...
Not much to go on, but sounds like your belt is off a pully. I can give a better answer with more info, but talke a look at belt system first. We will get you going.
Farmerbear
Aug 31, 2010 | Garden
DRUM DOES NOT TURN
Try turning the drum by hand. If it spins easily with no resistance, the belt has failed. On the back of the appliance you should find a label identifying the Make, Model, and Serial Number. Take down all the information provided, and then find a local appliance shop that carries that brand. Order the new belt.
Sep 17, 2009 | Dryers
My john deere lt 133 mower with a double blade mulching deck, 1 blade stopped working and only 1 blade cuts now, how do i fix this. Thanks Patrick
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
Aug 07, 2009 | Garden
Ariens 34 In. Zoom Series Riding Mower Logo
158 people viewed this question
Top Ariens Garden Experts
enb54
Level 1 Expert
Mike
Thomas F. Schneider
Are you an Ariens Garden Expert? Answer questions, earn points and help others
