Model TSI18A3W
Hello Frank;
My name is Peter. I am a retired field service refrigeration technician.
You have a general ice maker. Very Common. If you go to Sears, they want $116.00 for a new ice maker. Go into eBay and get one for $45.00 or less. Several models will work in your unit.
The front cover just pops off. I have to pull and use a small flat head screw driver to get it off.
Before you do anything, check to make sure you do not have a frozen fill tube. This is common.
Having removed the cover you will see the control module.
With a jumper wire, just ports 'T' & 'H' to manually run your ice maker. Remove the wire after 60 seconds and observe it running.
It is not uncommon to have the plastic gearing break, motor failureHow do I remove front cover on Amana Top Freezer i - 25332457-rljzekqxa22lq3uayqx0h0vi-4-8.jpg"/uploads/images/25332457-rljzekqxa22lq3uayqx0h0vi-4-8.jpg" alt="25332457-rljzekqxa22lq3uayqx0h0vi-4-8.jpg" class="h_mi" />
You can get a new control module on eBay for about $25.00. But still, you may also have a bad heater or thermostat.
May I suggest, buy a new unit on eBay and install.
Install:
1.) Remove the bottom hex head screw.
2.) Back off the two top screws until you can lift the ice maker up and away from the wall.
3.) With a small flat head screw driver, wedge the wire connector How do I remove front cover on Amana Top Freezer i - 25332457-rljzekqxa22lq3uayqx0h0vi-4-15.jpg ice maker as described above.
$38.00 Free Shipping - P/N
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
