It pauses by it self the I press start it will start again.
Wild guess, It's Out of balance, as a result, it's smart enough to stop spinning. To check, try to rebalance. Maybe overloaded. Remove clothes but fill with water and see if it will spin out. Second guess, belt drive on the bottom of the machine is worn, or belt tensioner is off or bad bearing. Also, possible the motor has a problem and shuts down because it's overheating a bit. If this is the case, though unlikely you will need a service man, but not cheap. If it's an old machine you might consider a replacement.
