Question about Kenmore Elite 45986 Front Load Washer
Washing Machine After having the main service line that brings water into the house replaced, the washing machine makes a LOUD whining sound from the cold water line that brings cold water into the machine. When I turn the cold water off the whining stops, but I don't want to have to wash everything in hot water. Help!
  • Anonymous Mar 12, 2014
    I have just moved house bringing this washing with me. However the new house has only a cold water feed. can the intellowasher be adjusted to support cold water only?
  • 249 Answers
Turn down water pressure going to the machine and see
Posted on Nov 29, 2007
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
When in spin cycle machine makes a very loud whining noise
Most common cause for your whining noise is because the seals have failed/worn and allowed water into the bearings..Rusty ball bearings are not smooth...Hence the noise.....Probably needs bearing/seal and probably shaft replacement....Big job..Get quotes....Good luck...Nomess
May 20, 2010 | Washing Machines
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
BEKO WMA641W washing machine not draining but pump working.
Are you sure the pump is working, or it the motor thats running? If the pump is truly working, there is a clog in pump or line. If the motor is working, but the pump is not, you will need to replace. You can usually buy a replacement pump for the washing machine for around $50. They are usually easy to install for a beginner DYI. Make sure you know the easiest way to remove washing machine housing to get at pump and motor. Unplug entire unit. Remove 2 hoses for pump and either screws or brackets to remove housing. BTW if the washing machine won't drain, you are going to have a bunch of water that gravity wants to dump out of machine. Bring pump to parts dealer for exact match.
Aug 21, 2009 | Washing Machines
Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
May 06, 2009 | Amana Washing Machines
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
Washing machine will not fill w/ hot or cold water
Could be an air lock in the water pipes,turn off the water to the washer, disconnect the hoses, and hold them over the sink or into a bucket, then turn the water taps back on to the washer.
The water should come through at full pressure.,
If it does not , then the problem is with your supply and not the washer.
Hope this helps.
Plz leave feedback.
Dec 09, 2008 | GE WBSE2090A Top Load Washer
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Maytag washing machine repair
The water pump may be going bad...Yes it probably is a bearing. Take the belt loose and try turning each pully until you find one that makes noise or is hard to turn. Pump and motor should both spin very easily with out noise.
Nov 27, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
75 people viewed this question
Sal De
 Brian Main
Brian Main
