Hardware & Accessories Logo
K
Kirk Posted on Dec 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do I have to program 1-7 with the my desired times to activate Monday thru Sunday? Or do I just program 1 out of the 1-7 to activate Monday thru Sunday...
Not enough time passed yet to see results
Mikey
Level 3:
Top Expert:
  • Master 6,904 Answers
  • Posted on Dec 21, 2014
 Mikey
Master
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1622890
Points
26106
Depends on what you are programming on and for?
I have a Honeywell programmable thermostat model RTH2300. Is there a way to program individual days
I believe Monday thru Friday has to be the same. Saturday and Sunday can be changed individually.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Cant access my paypal account
PAYPAL CUSTOMER SERVICE IS:
1-888-221-1161
gethuman.com/phone-number/PayPal/
Avg wait time is 20 minutes
4 am to 10 pm monday thru friday pst
6 am to 8 pm saturday and sunday pst
or have them call you thru the website above.
good luck
2helpful
Draw a flowchart to enter a number from 1 to 7 and disply the corresponding day of the week. hint: 1 = sunday
program days;
uses crt;
var
m,n:integer;
begin
clscr;
write('enter number of day');
readln(n);
m:=n mod 7;
case m of
1:write('sunday');
2:write('monday');
3:write('tuesday');
4:write('wednesday');
5:write('thursday');
6:write('friday');
7:write('saturday');
end;
end.
1helpful
2answers
Hey guys, the 15079 GE timer has 20 on/off settings. Are they for the whole week?
Eeeckles,
The timer you mention 15079 does has 20 on/off settings that can be set during a 1 week period that will then repeat each week. For example Setting 1 could be to come ON on Monday at 5:00pm and turn OFF Monday at 11:00pm while setting 2 could be to turn ON on MWF at 3:00pm and OFF MWF at 3:30pm.
You can find all of the UPDATE GE Timer manuals at the manufactures website: http://www.jascoproducts.com/support/timer-quick-start-guide.asp
Blessings!
9helpful
3answers
I bought a utilitech three outlet outdoor timer and cannot get it to set. Now I cannot seem to find the instructions that came with it. Where can I download the instructions?
I bought one also but am taking it back today as I am not satisfied with the performance and the internal battery dies losing all programming. The instructions below are word for word from the manual but not all that clear. Since I can't post the diagram from http://www.thencc.com/westinghouse/LS/Instruction/T28499_TimerManual.pdf (if I can post links here), I substituted words in the "Set Mode" section instead. This is for the Utilitech 0149289 model and also applies to the Westinghouse and Stanley equals. Good luck.
3-Outlet Photocell
HEAVY DUTY OUTDOOR TIMER
Tri-Mode Digital Timer
3-Wire Grounded Outlet and Plug
6 in (15cm) AWG 14/3 SJT vinyl cord
Rated: 125V/15A/1875W Tungsten
60Hz
INITIAL USE:
Before initial use, please plug in your timer for at least 1 hour to charge the internal battery. After the LCD display appears, your unit will be ready for programming.
RESET:
Press the "+" and "-" buttons at the same time to reset your timer. This will clear all programmed settings.
SET CURRENT TIME:
Press and hold the "TIME" button to enter the current time. First, set the day of the week: press "+" or "-" button to set today's day.
Press the "TIME" button to enter the hour setting. Press the "+" or "-" buttons to set the current hour. Be sure that AM or PM appears correctly.
Press the "TIME" button to enter the minute setting, Press the "+" or "-" buttons to set the current minute.
Press the "TIME" button to finish setting the current time and return to normal display.
SET MODE:
Press & hold the "MODE" button to scroll between the different Mode settings:
Display Mode Explanation
Digital Timer On/Off at your exact
programmed times (Picture of clock inserted here)
Photocell Countdown Timer On at Dusk or On immediately,
Off after 1-12 hours (Picture of what looks like half sun on horizon)
Digital Timer + Photocell On at Dusk, Off at your exact
programmed times (Combined picture of clock and half sun on horizon)
SET PROGRAM:
After choosing your mode, set the timer program by holding the "PROG" button for 3 seconds, and then follow the appropriate section below.
SET PROGRAM: DIGITAL TIMER
The first setting is "PROG 1 ON" which should appear on the screen. Set the desired day of the week setting for your timer using the "+" or "-" button to scroll between choices. You can select each day individually, Monday to Friday, Saturday/Sunday, or the entire week. To have your timer turn On/Off at the same times every day of the week, be sure to push "+" until all 7 days of the week are lit up for both PROG 1 ON and PROG 1 OFF.
Press "MANU" to enter the "PROG 1 ON" hour setting. Press the "+" or "-" to choose the desired hour for your timer to turn ON. Be sure to cycle through until AM or PM appears correctly.
Press "MANU" to enter the "PROG 1 ON" minute setting. Press the "+" or "-" to choose the desired minute for your timer to go on.
Press the "PROG" button to enter the "PROG 1 OFF" setting. Repeat steps 2 & 3 to set your desired Off time.
You may now either press the "PROG" button to enter additional programs (up to 8), or press the "TIME" button (or wait 15 seconds) to store your program. Your timer will now show the current set time and is ready for use.
SET PROGRAM: PHOTOCELL COUNTDOWN TIMER
The first setting is "PROG 1 ON". Set the desired day of the week program by pressing the "+" or "-" buttons. You can select each day individually, Monday to Friday, Saturday/Sunday, or an entire week. To have your timer turn On and Dusk and Off at the same time every day of the week, be sure to push "+" until
Press "MANU" to enter the hour setting. Press the "+" or "-" to set:
Display Explanation
d Dusk to Dawn - On at sundown, Off at sunrise
d:01 to d:12 On at Dusk, Off 1 to 12 hours later
S:01 to S:12 On immediately, Off 1 to 12 hours later
SET PROGRAM: DIGITAL TIMER + PHOTOCELL
The first setting is "PROG 1 OFF". Set the desired day of the week program by pressing the "+" or "-" buttons. You can select each day individually, Monday to Friday, Saturday/Sunday, or an entire week. To have your timer turn On and Dusk and Off at the same time every day of the week, be sure to push "+" until all 7 days of the week are lit up for both PROG 1 ON and PROG 1 OFF.
Press the "MANU" button to enter the "OFF" time hour setting. Press the "+" or "-" to set. Be sure to cycle through until AM or PM appears correctly.
Press the "MANU" button to enter the "OFF" time minute setting. Press the "+" or "-" to set.
You may now either press the "PROG" button to enter additional programs (up to 8), or press the "TIME" button (or wait 15 seconds) to store your program. Your timer will now show the current set time and be ready for use.
MANUAL OVERRIDE:
Press the "MANU" button to choose the timer status:
Display Explanation
ON Continuously ON
OFF Continuously OFF
AUTO Timer will turn On/Off according to program settings
Intermatic EH10: I can't figure out how to set a schedule of Sun - Thurs, 8am on, 10pm off and Fri & Sat, 8am on, 11pm off. I tried every day of the week 8am on, 10pm off and Fri & Sat 8am on, 11pm...
http://waterheatertimer.org/pdf/eh10-manual.pdf
The EH10 is 120V digital timer.
The timer offers the following days:
-All 7 days
-Monday thru Friday
-Saturday and Sunday
-Each individual day
-Blankday (day skipper)
If I understand your schedule:
You want
Program1 ON at 8am Sunday
Program1 OFF at 10pm Sunday
Program2 ON at 8am Monday thru Friday (with blankday on Friday)
program2 OFF at 10pm Monday thru Friday (with blankday on Friday)
Program3 ON at 8am Friday
Program3 OFF at 11pm Friday
Program4 ON at 8am Saturday
Program4 OFF at 11pm Saturday
I filled in the chart for you.
I left off the display.
I do not have this timer and don't know 100% how the display looks without buying the timer.
If you need more help on a specific step in the manual, add a comment and I will answer.
1helpful
Cant change the time on my work phone Panasonic KX-T7630
Try this - PRESS PROGRAM
Press 0
YYMMDD
Day of the Week (0=Sunday, 1=Monday ..... 6=Saturday)
HHMM (12 hour)
0 for AM 1 for PM
Store
PRESS PROGRAM
If that doesn't work I have no idea sorry. But I did find you this just in case http://www2.panasonic.com/consumer-electronics/support/Contact-Us.4
Hope I helped Dr Reed
2answers
Problem with Honeywell CM67z thermostat
yes you probably program it incorectly
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
