Mitsubishi WD-65732 65" Projection HDTV Logo
R
Rob Standard Posted on Dec 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn on TV picture color is green. How can I correct picture color?
When I turn on TV the color is very green. Is there a part that needs to be replaced?
gemagm
Level 3:
Master:
  • Mitsubishi Master 689 Answers
  • Posted on Jan 03, 2015
gemagm
Mitsubishi Master
Level 3:
Master:
Answers
689
Questions
0
Helped
119689
Points
1147
Check your input cables to be sure they are good & installed all the way, it that doesn't fix it you may need circuit board
DM PWB part# 934C225002
see this site for availability & price: http://www.shopjimmy.com/catalogsearch/result/?q=934c225002
OR this site: https://www.encompassparts.com/item/7065536/Mitsubishi/934C225002/Pwb-dm_%28V33%29_G $468.40 includes core price of $150.00
1helpful
My sony kp-51ws500 tv screen would turn green and stay on for about 30 sec, then trun off. I adjusted the green screen button on the black box in the front of the tv....via info from this site. It fix the...
Doing the adjustment is not actually a fix, all that does is change the drive amount of the green CRT which allows the set to work but the 3 CRts will be out of balance so picture color will be affected. The only way to repair a bad CRT is to replace the CRT itself. You can get replacement Green CRT from www.tvrepairworld.com
When tv has been off awhile and turned on picture
Tube tv?U know how to solders?Ur video board have problems.Change all the capacitors,which one don't know must troubleshoot, the cpacitor the cause no clues,best change all of it.
Projection tv 42" panosonic hdtv. to much green in the picture. Jeff
this unit may have a resistor on the green crt-board that has increased in value. check ohms(resistance) on all crt boards and compare to one another. these will have color bands that inicate value of resistance. you do not need to know color code, just match colors of resistors on each board then measure. you could also have weak green tube. turning down the master screen control located on the fous/screen block can reduce grn. drive. to adjust proper drive for each so the grey scale is correct, turn color to tv all the way down then adjust screen controls on block for black & white picture. when color is turned all the way down, you should not have any green, red, or blue over cast on screen. mch
1helpful
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Pink Picture
You TV missing Green color ratio to produce correct colors in picture. It might needs service and adjustments in Video section .
Screen colors not constant
You probablly have bad solder joints on your Video driver transistors, which arre located on each Picture Tube. You can only get to those by going through the front, grille cover
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
