Question about RCA G27692AT 27" TV
Lost functionality w/ remotedfdf
  • RCA Master
  • 19,396 Answers
Re: Lost functionality w/ remotedfdf
0 characters
3 Points
Esa et419e manual
No. There is not such function to this TV.
May 29, 2013 | Standard (CRT) Televisions
I have a emerson dvd tv , how to make screen bigger we lost remote
Hi, If you have your DVD remote it may have some setting to make it wider. You said you lost your remote to the TV. You can buy a universal remote that have some TV functions like on/off channel up/down Play/pause for DVD or CD players and VCRs. But go to a audio/video place and order a remote for your TV. Just tell them make and moder #no. It may cost a bit more than the uni- remote. Good luck
Jul 19, 2011 | Emerson Standard (CRT) Televisions
My TRINITON KV-DR34M89 has lost sound and image only PIP function but can not SWAP to main screen
Possible problem in the processor control unit. it must be probed to see if both the issues arelinked to the same fault. the processor could have muted the sound and picture due to a failure of the function or subfunctional circuits. This requires a stage by stage check possibly using signal injection, signal tracing using an oscilloscope and a good mutlimeter. It can also be failure of a digital GATE- circuit., an I.C linked for switching the sound and picture.
Jul 05, 2011 | Standard (CRT) Televisions
How can i autotune my soney trinitron tv iv lost the manual
Enter menu, and select the [autotune or auto search] function with the help of Prog+ Prog- and Vol+ and Vol- buttons. After that function highlighted press Vol+ button once and release. The TV will tune and store automatically in its memory, all the transmitting stations at that time, and after tuned the entire band it will finish tuning and will display the first channel. You must select auto tune for this. Not manual tune or fine tune functions. A horizontal bar will run across the bottom side of the screen indicating that the tuning process is in progress, and it will reset three times to zero and will continue tuning. It is due to the auto band selection is done inside the microcomputer of the tv. No other functions will response anymore, till autotune process is completed. Ok.
Oct 19, 2010 | Sony Standard (CRT) Televisions
Is tv broken or remote?
The batteries may need to be replaced. If the batteries have some power they may partially function but cannot due all the functions that are required to perform. Your batteries may have lost partial contact. Open the case and readjust the batteries in the case.
Aug 21, 2009 | Sanyo DS31590 31" TV
Remote control ceased functions to RCA Home Theater Guide Plus
Frist of all your main problem is that you have a rca. You probley have some bad capastors that have lost there value. You probley will have to take to a shop for repair.
Mar 05, 2009 | RCA F32648 32" TV
Blue screen and a small red key
worked just fine for me! thanks!!! 'function' key is in the top left hand corner
Mar 16, 2008 | Apex Digital AT2402 24" TV
Function switch doesn't work
This is due to switch malfunction problem. Dust and corrosions shows these type of problem. Make one general service by technical person. Or if you have keypad lock system in your menu options lock your keypad control. The TV will work.
Aug 28, 2007 | Toshiba 32A33 32" TV
No input channels
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc. This is even written in the manual that they do not guarantee that all functionality can be used. Here are your options: 1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need. 2. Buy the original model remote control. 3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control. I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
May 23, 2007 | Symphonic ST419E TV
Standard (CRT) Televisions Logo
105 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
