Usually the power steering pump is the most likely culprit. Check you power steering fluid level. If it is good and there is no power steering, then the pump is probably not pressurizing the system. It is doubtful that the fluid has leaked out entirely as most power steering pumps are lubricated by the fluid and total loss of fluid would result in a terrible shrieking sound and almost certain pump destruction. Other causes could be a bad or leaking rack. Look for leaks at the rack boots.
In
relation to these problem there is solved help link,i suggest you to go click the link below and troubleshoot the problem:-----
POWER STEERING TROUBLESHOOTING,
STEERING SQUEAKS, POWER STEERING FLUID LEAKS, FAULTY POWER STEERING PUMP, POWER
STEERING NOT WORKING, POWER STEERING BELT,
http://alltypesofpartsreplacing.blogspot.com/2012/12/power-steering-troubleshooting-steering.html
These will help.
Thanks.
In
relation to these problem there are few solved help links,i suggest you to go
through the list and click the required link:-----
http://schematicsdiagram.blogspot.in/2012/04/power-steering-going-out.html
http://schematicsdiagram.blogspot.com/2011/12/steering-wheel-locked.html
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-power-steering-pressure.html
http://howtobyme.blogspot.com/2012/01/how-to-replace-power-steering-pump-on.html
http://repairhelpcenter.blogspot.in/2012/02/how-to-bleed-power-steering-pump-on.html
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-steering-pump-on.html
http://technoanswers.blogspot.in/2012/02/steering-service-light-on-gmc-sierra.html
http://technoanswers.blogspot.in/2012/02/on-one-my-pontiac-grand-prix-relatred.html
http://schematicsdiagram.blogspot.in/2012/02/check-power-steering-message-on-toyota.html
http://carbeltrouting.blogspot.com/2011/12/1992-ford-aerostar-power-steering-and.html
Also bleeding:
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-linkage-on.html
http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-pressure.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-wheel-on-acura.html
http://howtobyme.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
These details will help.
Thanks.
How to bleed power steering pump on Toyota?
----------How to replace power steering pump on Toyota Land cruiser?
Steering service light ON GMC Sierra Denali?
Steering service light came on 2004 Pontiac Grand Prix
Check power steering message on Toyota?
How to remove power steering pulley on 2002 Ford Taurus?
http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-steering-pulley-on.html
---------1992 Ford Aerostar Power steering and
Alternator belt routing diagram?
How to replace Power Steering Pump on Acura
Car Models?
Also bleeding:
How to replace Steering Linkage on Acura Car
Models?
How to replace power steering pressure hose on mustang?
STEERING SQUEAKS
http://alltypesofpartsreplacing.blogspot.com/2012/10/steering-squeaks.html
Steering
Column Diagram For 1990 Jeep Wrangler
http://schematicsdiagram.blogspot.in/2012/07/steering-column-diagram-for-1990-jeep.html
How to replace Steering Wheel on Acura Car
Models?
How to replace Power Steering Pump on 1999
Acura TL?
Thanks.
