You need a RCA sub-woofer cable (analog mono) to connect between the receiver's sub-woofer Pre Out and the sub-woofer. This cable has a single RCA plug at each end of the cable. The cable is somewhat thicker than some audio RCA cables. You can use any RCA cable temporarily.
Hello Keith, You should be able to hook up any monitor to the receiver via HDMI as long as it is 1080p resolution or lower. Just be sure to keep the HDMI cable to 12 feet or less. Thanks, FJD
Hi Paul, I am sorry you are experiencing problems with your receiver. If the unit will not power on you will have to take your unit to one of our authorized service centers for repair. You can locate an authorized service center at the following link, http://www.onkyousa.com/Support/servicecenterLocator.php?source=globalnav. If you require further assistance please feel free to email us at [email protected], Thanks, JT
easy.connect the dvd trough optical cable to the amplifier home theatre for surround sound and the video where it says DVD input and the sony cassete deck where it says cd in A/V the red cable wwhite and yellow,
If the system uses a remote control, you may need to adjust the subwoofer out signal setting or turn on the sub in a menu, and on many systems, you can only access those settings via a remote control (you should check the onkyo user manual on how to do it).
Now, this is just one suggestion, it may work, but then again, it may not.
These could also be connection problems or some internal trouble in the onkyo sub signal output section or in the subwoofer input section, but hopefuly, it's just a "turn on" or "signal level" setting in a menu.
"Sub-woofer output not working" problem, and notify you when a new solution is offered. Press the setup key on the front of the receiver Select the subw setting Move the multicontrol knob until the sub woofer is on Turn off the receiver and turn back on- the subwoofer should be on The operator manual can be downloaded on the web site--- free http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
