Tablets & eReaders Logo
B
Billy E James Posted on Dec 20, 2014
How do I turn on the bluetooth on my Z T PAD
Every time I try to turn bluetooth on it kicks right back off
moorelove
Level 1:
Filmmaker:
Uploaded 5 video answers.
  • Contributor 34 Answers
  • Posted on Dec 20, 2014
moorelove
Contributor
Level 1:
Filmmaker:
Answers
34
Questions
0
Helped
16149
Points
49
You must turn on the tablet's Bluetooth radio before you can enjoy using any Bluetoothy peripherals. Here's how to activate Bluetooth on an Android tablet:
  1. Open the Settings app.
  2. On some Samsung tablets, touch the Connections tab.
  3. Ensure that the master control next to the Bluetooth item is set to On.
    Slide the icon to the right to activate.
    When Bluetooth is on, the Bluetooth status icon appears. It uses the Bluetooth logo.
To turn off Bluetooth, repeat these steps, but slide the master control to the left, to the Off position.
You'll also find a Bluetooth switch in the tablet's Quick Actions.
I keep getting kicked out of games on my NextBook that no other device in the house is having a problem with
lok at what is running on notebook, look at app to see what is running, turn off games that are not being used, keep in mind most app come on when you turn on the pad. some may need to be uninstalled, if not used. be sure too only uninstall games so you don t uninstall parts of the note pad programs.
How do I turn on with Bluetooth from existing ipad
Open the Settings app, go to Bluetooth (near the top of the list), then on the right side of the screen, slide the Bluetooth switch to the right.
My asus memo pad 7 wont send, receive or pair with devices through Bluetooth
hai there, as i analyze, you have to pair manually to other device, cannot straight send file to the others by bluetooth.
before send file and other thing, first make sure some one or other device you want to send have to be recognized by your device by pairing manually.
you have to go to bluetooth setting, for pairing manually you can choose by search or by listening device, don't forget the other device must do the same. after your device completed pairing to the others you can transfer all files you want.
cheers. hope its helps
Can I link tablets without usb or bluetooth
As soon as you can't use the input device, you can't setup any connection. The best this for you, and I think the only thing, to get your data from the Pad, is to connect it to a computer via USB and hope you can acces your files.
Bluetooth won.t connect
You may need to pair the bluetooth again as it may have lost its pairing id sync.
Delete the pairing if it exists and start from the beginning.
I can't now can't get my bluetooth to work on my asus memo pad hd7
What bluetooth are you trying to pair?
Make sure bluetooth is enabled on both devices.
Sync ihome wireless keyboard
Say the device you want to sync your keyboard to is an I pad.
Follow the I pad's normal Bluetooth pairing procedure. Around the same time, slide the switch on the back of the ip2101 from OFF to ON and then press the black button to the left of that switch. When the I pad recognizes the ip2101 keyboard, the I pad will display a pin number and instructions to type that pin number on the ip2101 keyboard and hit the enter key on the ip2101.
5helpful
2answers
I have a ARCHOS 28 internet tablet and the touch screen is not responding to any contact. what should i do?
We had a similar problem yesterday. It happens as soon as we plug in to USB cable to PC. We found that after we left it for some time it did eventualy kick back in to life. We could use it until we plugged in to USB again. Trying to find a solution to the problem right now. You can press and keep hold of volume up button while you turn back on and that kicks in the diagnostic software menu. From there you can find the "Force screen calibration" which we did but it doesnt sort out the problem of plugging in USB
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
