Question about Mitsubishi Lt-40164 40 Inch Unisen Led Tv
Green Blinking light on Mitsubishi Unisen lt 40164, tv wont turn on?
Tried unplugging and waiting overnight, tried holding down power button.
    President:
  • Mitsubishi Master
  • 777 Answers
There is a known problem that develops over time with the main board of this Mitsubishi LT40164.
See
http://www.coppelltvrepair.com/p/1635/repair-service-for-mitsubishi-main-board-934c374002-causing-dead-tv-blinking-loop-no-hdmi-no-audio-etc-problems
Posted on Jun 14, 2018
    President:
  • 1,755 Answers
Hi Since that did not work, The next thing is you have to take the back off the TV and find the main power board. On that board there will be some bad capacitors. Look for bulged or leaking CAP(s).
Replace them with same capacitors types. If you're not tech. savy Go to TV repairman. Good luck.
Posted on Dec 20, 2014
SOURCE:
SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Posted on Nov 24, 2007
  • 8457 Answers
SOURCE: My mitsubishi Model # WD-60737.
Tv under a year old call Misubishi for a warrenty repair.Flashes staus light mean could be any these parts have problems power supply board,Ballast board or the pojection lamp itself.
Posted on Jan 11, 2011
i had the same problem and i called mitsubishi they said it is a software malfunction and they are sending me an update to install via flash drive. i am now awaiting the email
  • 3 Answers
SOURCE: I have a Mitsubishi LT46265. My TV downloaded a
Hold the power button on the side of the TV (not the remote) for 10 seconds or so to force a reboot. Otherwise, unplug it for an hour.
-Mr_E
Posted on Feb 06, 2011
electrotech1
  • 1126 Answers
SOURCE: On a mitsubishi tv (LT-46149)
It is possible that you have a bad power supply, or the TV has been hit by a small power surge and if you unplug the set from the wall for 40Min., it will rest back to normal.
Blinking light means your bulb is blown and needs to be replaced. Very easy to do. Check owners Manuel . Shop the bulb on ebay
Dec 19, 2014 | Mitsubishi Lt-40164 40 Inch Unisen Led Tv
Kindle fire screen repair
Press and hold the power button for fifteen seconds or so. Does it turn off then? If so, press and hold the power button for a second or two. Does it start to reboot then? Does it work properly now?
May 26, 2013 | Amazon Kindle Fire HD
I get the following error message from C5180 printer: 0xc18a0001. What should I do?
Hi there
0xc18a0001.
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C6280 printer won't print and displays Ink System Failure message and Error #0xc18a0001.
Hi there
0xc18a0001.
5. Wait 60 seconds.
Or try 2
Or try 3
Feb 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Sharp 46 aquos model LC46E77UN tv turned off power button just flashes on and off tried unplugging and waited an hour and replugged same conclusion power light just flashes
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Oct 01, 2009 | Sharp Televison & Video
Lightning Last Night Nocked The Receiver Out.
leave unpluged overnight. usually capacitors hold charge and will release slowly. try that if doesnt work powersupply is bad.
Jun 03, 2009 | Yamaha RX-V861 Receiver
Help Urgent
Hi Natasha,
If the button settings didn't help, then try resetting the printer.I have mentioned all 3 kinds of resetting, try and let me know.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the Ink Cartridges, then unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds then release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks n Regards
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Screen locked on "Checking media"
When the radio locks up on the Checking Media page you hold the + button to the volume and the MODE button wait for 3 seconds and it will turn off...  Thanks to Delphi for this assistance!!  Chris K.
Jun 02, 2008 | Delphi SKYFi3 XM Radio Receiver
Mitsubishi Lt-40164 40 Inch Unisen Led Tv Logo
1,730 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
