You have a short circuit somewhere and this is likely what drained your battery. Could be a bad alternator, wire rubbed through insulation, or other short. Get someone to look under hood while you try to crank it and see if they can tell where smoke is coming from. As an old professor once told me "All electrical circuits run on smoke. Be careful not to let it get out!" lol.
SOURCE: Car won't start even after new battery purchase
Alternator problem, the alternator charges the battery when car is running, so it has probably died now. Was working at reduced capacity for a while, which is why you were only getting a partial charge for some time. Now you have an open circuit completely as alternator has failed completely, time for a visit to an auto electrician. PS replacing acid in battery with distilled water is not a good idea. It probably was time for a new battery anyway.
SOURCE: 2000 Jetta is Leaking antifreeze and smoking
I think you mean you saw water vapor (some call it steam) not smoke.
You probably have a hose leaking (badly). If it's not a hose, your water pump shaft seal is probably kaput.
SOURCE: 2003 Ford Escape won't keep running
2 solutions: first, ignition control module is getting hot and shutting car down. 2nd; you didn't mention your dash(service soon) lights were on.<p>
You said the fuel filter was pretty clogged up. It's sounds like a bad case of EGS(ethanol gas syndrome). The ethanol;being a corn deritive;acts like corn liquor(which is what is is), and turns the fuel to goop, and adds large amounts of water through out all the systems.<p>
It clogs up the fuel lines,the injectors, and ruins fuel pumps. It also puts heavy carbon on egr valves, int. and exh. valves, and can ruin oxy sensors, and catalytic converters.<p>
Let's try the cheapest way first:Buy a can of SEAFOAM and Berkline 2+2 at your parts store. Take out the oxy sensor(s) and clean the ends using the 2+2 and re-install.
Then change out the fuel filter again. Pour the SF into a tank of PREMIUM(only) gas. Change the pcv valve. Then start vehicle and let idle for 3-5 min(even if you have to rev it up to do it to get the SF flowing through the system), and then drive it 10 hard miles.<p>
Replace that fuel filter, and then let it idle some more. Your car sounds like it is really messed up bad. Unless you take it to a garage that has a fuel system cleaner machine, this is the best way to do it.<p>
After this, add SF every 3-5000 miles to your tank. It will prevent this from happening again. Also; to be on the safe side. Have a PSI check on your fuel pump. This goop could have burnt it up. I hope this helps.
SOURCE: 87 f250 drained brand new battery
I would first have the alternator checked by an auto electrician to ensure it is working correctly and is providing the correct volume of current. It may be faulty and when driving you will be drawing battery power instead of power from the alternator to run the electrics. This will drain the battery.
Alternators do not last forever and if you are still running the original unit it is likely to be on it's last legs and you will need a replacement unit.
