The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
does the television stay on ? these codes or flashing lights and designed to tell you about a problem that the internal computer had detected - a single flash then a double flash is a software upgrade notification -- call support at customer service and they will tell you exactly what the flash is related to then you can find the fix or repair with more information
You have sound but no picture. Green power light is on and NOT flashing. You get a screen flash or flicker on power-up or even a minute of screen before going all black. It is your inverter board. Common problem on LCDs (maybe more so on Phillips?). They are easy to replace (unplug-plug) and are available on the net.
