Question about LG DLE2532W Electric Dryer
LG DLG2532W Gas dryer problem
My LG Gas dryer does not heat. I have checked the venting. It is okay (even to outside I see good airflow). I cleaned the humidity sensor (per customer service recommendation). Still does not heat. I also checked circuit breaker outside the house and it is okay.
Help!
Adam
  • 6 more comments
  • stevemn Dec 07, 2007
    I'm having the same problem. DLG2532W Dryer won't heat. I've replaced the Thermostat assemblies, but it still won't heat.
    It did fire up once I put a new Frame Detect in, but it failed to heat shortly after that.
    The vent has been cleaned and the venting is clear.
    The Ignitor reads 300+ ohms, and the gas valves both read 1.8k ohms.
    Help!
    Steve
  • stevemn Dec 09, 2007
    DLG2532W Not heating; Gas Dryer. I did try to bypass the thermostats. Each of the one at a time; They have been replaced, but they still test out ok. Still does not work. Even with all of them bypassed.
    I tried with a jump wire, and directly taping them together.
    The ignitor still doesn't glow. It does test out over 300 ohms.
    Thoughts? About the only thing I haven't replaced is the control panel and the ignitor.
    Steve
  • tjsoftball9 Jan 14, 2008
    I have the same problem on my DLG2532W, I would dry one set of clothes and then on my second load after it went through the time, the clothes are cold. After the first time I noticed it, had a repair man come out, luckily I purchased the extended warranty with Best Buy, but the repair man took about a week to come and see it since he was from out of town since no one here could repair LG's. He said it was just a circuit breaker that trips when it gets too hot, since that is how the machine is, which is good, but not good when it trips every time you do a load of laundry!!!! The repair man should be what to do, which was the greatest think ever!!! But because it is a pain to take out the screw everytime it trips, I now have my dryer constantly apart so it is easier to push in the circuit. On my machine, you need to unplug the machine, or else you will get a little shock if you don't touch the right spot. You have to pop open the top of the machine, unscrew the top 2 screws of the machine and unscrew the screws around the circle so the front part of the machine comes off so you see the parts. The circuit is located on the bottom right of my machine between 2 wires, if you press it, you hear a click and then try the machine to see if it works now.
    Hope that helps, frustrated LG owner like everyone else!!!!
  • jiggilypuff Sep 20, 2008
    dried a load of laundry on sunday and everything was fine. Friday it just runs cold no heat. the cooling light stays on,.
  • Anonymous Sep 24, 2008
    not drying
  • spunkyboss Nov 27, 2008
    i had the same no heating problem with my lg dlg2532w dryer and i followed your advice from this column and suprize she works again! like stated remove the front panel and door and in the lower right side panel on the side of the flame tube are two wires and in the middle of them is a button you really cant see but can feel by touch just push it till you hear and feel a click then should have hopefully fixed your heating problem as it did mine!!!! thanks for the info worked great!!!!!!!!!!!!!1
  • haugenmd Dec 22, 2008
    I tried the circuit bbutton reset trick and it worked!! Yippee! It's a pain to take the thing apart, but with 4 kids, I can't afford to not have it working. I had a difficult time finding the button on my dryer. It's a white button, not on the right side, but about 6" towards the center from the right side and about 7" towards the back near two wires connecting to what looks like a metal cylinder on the left side of the cylinder. Thanks so much for posting this! I will never buy this brand again - have both washer and dryer - they have worked hard for 5 years, but I am always unplugging them and cleaning out the washer filter. My dryer drum is cracked and makes a thump thump sound - like a loud heartbeat, and now this! Sometimes I wish they would just toast so I could get rid of them! Dawn in MN
  • Anonymous May 06, 2009
    no heat
Dryer working and heating properly, when cycle complete all my clothes smell like gas though. Any suggestion
Posted on Jul 05, 2010
  • 2 more comments
  • ariemiko2 Sep 11, 2010
    LG DRYER NOT HEATING ????? ****PLEASE READ THIS LG DRYER UPDATE!!!!! ****
    I READ AND FOLLOWED THE SUGGESTIONS ABOVE AND IT WORKED!!!!! AND I SAVED HUNDREDS! LET ME WALK YOU THRU.
    (UNPLUG THE ELECTRICAL CORD BEFORE FOLLOWING THESE STEPS)
    1.ON TOP OF DRYER THERE ARE SCREWS ON BACK, UNSCREWING THESE WILL ALLOW YOU TO PULL TOP OFF (IT SLIDES AWAY FROM DRYER)
    2. NOW THAT TOP IS OFF, UNSCREW SCREWS OFF OF TOP FRONT PANEL (SCREWS ARE ON BACK OF FRONT PANEL BUT CAN ONLY BE SCREWED OFF IF TOP IS OFF)
    3. NOW OPEN DRYER FRONT DOOR AND UNSCREW 2 SCREWS UNDER LINT CATCHER AREA, SCREWS FACE THE FRONT - NOW THE WHOLE BOTTOM FRONT PANEL WITH DOOR WILL CAN COME OFF TO ACCESS THE BOTTOM OF DRYER
    4. ON LOWER RIGHT HAND CORNER OF DRYER THERE'S AN AREA WITH WIRES AND PARTS - LOOK TOWARDS BACK ALONG RIGHT SIDE OF BOTTOM OF DRYER (ABOUT 6 - 7 INCHES TOWARDS BACK)
    (FLASHLIGHT MAKES EASY TO SEE)
    5.LOCATE THE FLAME TUBE WHICH LOOKS LIKE AN OPEN CYLINDER (THIS IS A FEW INCHES FROM RIGHT SIDE TOWARDS CENTER OF DRYER) - ON THE LEFT BOTTOM SIDE OF THIS FLAME TUBE THERE ARE 2 SETS OF WIRES (1 IN THE INSIDE OF THIS FLAME TUBE AND 1 ON THE OUTSIDE OF THE FLAME TUBE) THE 1 SET OF TWO WIRES THATS INSIDE OF FLAME TUBE IS WHERE YOU WILL BE LOCATING A "BUTTON OR PIN SWITCH" - THIS WILL BE RIGHT BETWEEN BOTH WIRES (MINE WAS BLACK COLOR BUTTON ON A METAL PIN).
    "PUSH / CLICK" THIS BUTTON BUT MAKE SURE THERE IS NO NOISE AROUND YOU BECAUSE YOU NEED TO HEAR TO MAKE SURE YOU HEAR A "CLICK" SOUND - I MISSED IT BUT ONCE CLICKED IT WONT CLICK AGAIN BUT ITS OK CUZ IT WILL WORK).
    6. BEFORE PUTTING EVERTHING BACK TOGETHER I HIGHLY SUGGEST YOU VACUUM OUT ALL LINT/ DUST BUNNIES FROM THE INSIDE OF THE AREA YOU WERE JUST IN (AROUND THE FLAME TUBE). i EVEN UNSCREWED THE OUTSIDE OF LINT CATCHER TOOK IT OFF (EASY) AND CLEANED IT. I ALSO VACUUMED THE BACK OF DRYER WHERE EXHAUST COMES OUT AND VACUUMED THE VENT THAT GOES TO WALL AND THE VENT GOING UP TO MY ATTIC AND MADE SURE THE AIR FLOW WAS GOOD THROUGHT THAT WHOLE AREA (SHOP VAC WORKED GOOD CUZ YOU CAN USE IT TO VACUUM BOTH BY SUCKING AND BLOWING AIR INTO THE AREAS WHERE VENTING / EXHAUST OCCUR).
    7. PUT ALL PARTS AND SCREWS BACK, PLUG IN AND TURN DRYER ON WITH WET CLOTHES IN IT ...
  • joe6583 Nov 06, 2010
    Thanks this worked really well. For the top removal only take out the three screws along the back. you dont have to take off the control panel. Then along the front edge there are two tabs hold down the top just push a flat head screw driver in and it will pop up.
  • Chris
    Chris Oct 16, 2013
    THANK YOU for this solution--worked perfectly. I agree with Joe that the easier way to open the top is to stick a screw driver in the front corners and pry it up. The spring loaded latches will snap open. When all the way inside I couldn't actually see the button, but felt for it between the two wires (which were actually on the outside of the tube) and felt the button. Highly recommend cleaning out the lint trap assembly while you've got the whole front open--very easy and I found tons of lint there. Thanks again, Ariemiko. Great solution.
  • David Ende
    David Ende Sep 07, 2014
    followed the advice from Ariemiko2.... and it worked!!! It took a while for me to find this solution. I had tested every thing else and every thing checked out. This saved me from buying a new machine. Thanks
    New Friend:
Pressing the black button worked great.
Thanks for the advice.
Posted on Apr 16, 2013
Actually, it was the Control Panel that went bad. It's not too expensive, and has been working find. The toughest part of replacing it was getting the buttons to line up. Have a 2nd pair of hands to help you.
Hope this helps!
Posted on Feb 20, 2008
Check the thermostat assem..if your looking at the dryer its on the left side below the igniter on the igniter tube its black round with a metal bracket holding it on..unplug the machine take the two conectors off and jump them with a wire, plugit back in and test...if it works youneed that part..
Posted on Dec 08, 2007
  • discovery_to
    discovery_to Jul 05, 2013
    What does it mean to "jump them with a wire"?
I just purchase my LG front load gas dyer and am wondering what types of problems to expect and what people are doing about it....
Posted on Feb 19, 2008
  • Dee08 Feb 19, 2008
    I just purchase the LG Gas Washer & Dyer and heard people are having problems with it. Sears would not comment, can anyone tell me what to do and how to find out the solutions.
    Dee08
Clothes aren't drying...
First check and clean the lint trap. Next turn on the dryer and go outside to the dryer vent and make sure you have good airflow coming out. If you don't have good airflow then there is a blockage in the vent system somewhere.
Jul 26, 2012 | LG DLE7177 Dryer
My DLG2532W just stopped getting hot, is this an easy fix or do i need an expert to fix it?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 03, 2011 | LG Dryers
LG dryer DLE2516W - everything runs but no heat, 18 months old, checked lint trap and vent to outside, the plug over heated and melted slightly so bought a new plug and new house outlet, dryer worked for a...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | LG DLE2516 Electric Dryer
Unit powers up, check filter light flashes until you turn main control knob to any setting (e.g 'normal'). Press start, unit runs, but no heat. Checked output of vent outside, plenty of cool air is flowing...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 14, 2010 | LG DLG5988 Gas Dryer
Gas dry is not heating enough to dry clothes
There is two possible causes. Either your gas coils are going bad late in the cycle or your venting is restricted. I would go outside check to make sure you have good airflow. If you have good airflow outside the only common cause of gas dryers failing to heat late in the cycle would be gas coils. If you have a peep hole on your dryer look in it after your dryer has been running for approx 30 mins and see if the ignitor glows and then shuts off. If the burner does not kick on then you have bad gas coils. They are part number 5303931775.
Let me know if this helps _MJ_
Jan 29, 2010 | Maytag MDG2600BWW Gas Dryer
I HAVE A LG GAS DRYER...MODEL NUMBER DLG2532W...THE PROBLEM, WHEN I WAS ATTEMPTING TO RESET THE THERMOSTAT BUTTOM, I ACCIDENTALLY BROKE A PART THAT HAS A COIL AROUND IT WHICH I THINK GETS HOT AND i THINK...
OK i see the other modle #.
Yes the ignitor can be replaced part# 5318EL3001A
If you have to reset the thermal fuse your vent is clogged so be sure to clean the vent all the way to the outside.
Jan 17, 2010 | LG DLE0332 Gas Dryer
80 modle gas
The dryer may be free of lint, but what about the vent that comes out of the dryer into the wall, than also the vent going through the wall to the outside. This is where the problem usually is. Try and check the vent outside the house. Feel how much air is blowing out. It should be pretty strong, not just a light breeze. Even a small restriction in airflow will cause the heat to shhut off prematurely. Its a very good idea to include professional dryer vent cleaning as part of the yearly maintanance. This is one of ythe leading causes of dryer fires. Hope this helps, dave www.washermd.com
Dec 17, 2008 | Kenmore Dryers
LG DRYER DLG2532W GAS
Dryer doesn't get hot. Replaced all the sensors and still it doesn't get hot. Doesn't get hot in any mode. All vents are clear. I'm thinking that maybe there may not gas getting ignited, but I know nothing about gas stuff and am not sure if thats the problem. Any ideas of what I should be looking at next?
May 15, 2008 | LG DLG2532 Gas Dryer
Dryer heating problems
You have this under "gas dryer" but by the model number it's an electrics dryer. There are 3 things you can check yourself first, 1) Check for blown fuses or popped circuit breakers. 2) Check the connections where the wires go in the back of the dryer 3) Make sure you have good airflow coming out of the vent outside your house. If all of these are good then you will have to call for service.
Dec 21, 2007 | LG DLE0332 Gas Dryer
I have a lg dryer model dlg2532w gas dryer it does get warm
if the cloths are warm and wet the problem is not with the dryer but in the venting. check the air flow at the end of the line (where the exhaust leaves the building) if the air baffels are not fully opening when the drier is on there is probably an issue with the venting. remember to tape up the venting joints after inspecting it because it is also the exhaust for the gas. hope this helps.
Sep 25, 2007 | LG DLG5988 Gas Dryer
LG DLE2532W Electric Dryer Logo
4,277 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
