Will not chnge to New York State. says no matches found?
SOURCE: Garmin Nuvi cannot find a new location
Check to make sure your maps are checked off. Go to settings, Map, then press Map Info at the bottom of the screen. Make sure City Navigator North America NT v8 has a check mark on it.
SOURCE: Cannot insert addresses!
Got it!! For those getting the "No Matches Found" headache. Here's the solution:1. Go to "Settings" 2. Go to "Map" 3. Go to "Map Info" 4. MAKE SURE that "City Navigator North America NT 2008" is CHECKED. It fixed the problem for me. Hopefully it will fix yours all the same. God Bless.
SOURCE: Garmin Nuvi --Can't put state in for address
Turn on the unit and go to Settings
Then select Map
Then select Map Info
Verify that there is a check mark next to City Navigator North America NT
SOURCE: No matches found on garmin 350
Click on the wrench symbol, then the map icon and then "map info". Make sure your map is checked. If it's not, then your map is off. When its off you wont find anything.
- Jim
SHARCNET-USA
SOURCE: Default state changing
If you are talking about your home location all you have to do is go to your TOOLS / MY DATA / SET HOME LOCATION. You can then set your HOME location to anywhere you want. This is the only default location I am aware of. If this isn't what you were looking for let me know and I can dig into it.
