I have an audi a4 02 and i was told i have a messed up sensor because my water tank is broken and leaks on it. My car dies and then re starts hours later whenever i turn on the radio it dies faster than other days. I work about an hour away so time itll go days without dying other times every other day etc. sometimes my wheel will lick then it dies when am ggetting off exits at lights whenever i slow down some way. I wanna buy the sensor to replace it but nobody can tell me what its called. Does anybody know if it is the sensor or maybe something else? Im already gonna replace the water tub so am hoping once i replace both sensor and tub it will be fine. Any suggestions or thoughts on the symptoms ?
SOURCE: 1993 Volvo 850 wont start...help?!
It sounds like your fuel pump is having a problem with getting the last of the fuel from your tank. The pump also has a strainer on it. The unfortunate reality with the 1993 Volvo 850 is that the pump and strainer are located inside of your gas tank. You can look for kinks or pinched areas in the line but from your description it sounds like the pump is going. It has to work much harder when the fuel is low in the tank.
