2008 Nissan Quest Logo
c
craig essick Posted on Dec 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace lift gate motor on 2008 Nissan quest?
Nothing
Richard Warren
Level 3:
Genius:
  • Nissan Master 2,548 Answers
  • Posted on Feb 06, 2015
Richard Warren
Nissan Master
Level 3:
Genius:
Answers
2548
Questions
Helped
639747
Points
6606
Check fuse and power to rear gate , motor is inside the tail gate.
5 Related Answers
Anonymous
  • 365 Answers
  • Posted on Jun 15, 2009
SOURCE: Infinit QX56/Nissan Armada power lift gate problem
Go to your local body shop...should only be $50 to fix or maybe free to get their advise.
Good Luck
John M Grubb Sr
  • 65 Answers
  • Posted on May 22, 2010
SOURCE: 2008 Tahoe: The automatic back lift gate on my 2008 Tahoe stop...
I found this URL on internet http://www.chefseattle.com/blog/site-news/suburban-rear-liftgate-wont-unlock-how-to-fix/ If your vehicle is similiar maybe it can help.
Joseph Hoffmann
  • 1756 Answers
  • Posted on Jun 10, 2011
SOURCE: My lift gate indicateor light is on but the gate
You have a bad switch on door or latch. Replace as needed.
chargerhp
chargerhp
  • 815 Answers
  • Posted on Dec 05, 2011
SOURCE: 2005 Chrysler Pacifica lift gate
You are right
Anonymous
  • 6468 Answers
  • Posted on May 28, 2012
SOURCE: 2007 nissan quest power lift gate problem
check the hydrolic struts on the lift gate
I have a 2008 Nissan Quest with auto doors and the sliding glass door on drivers side won't open from in or outside. Can anyone help me?
Did you turn the auto open button off ? It is one of the buttons on the roof console by the phone icon. Does the tail gate open?
How do I replace the lift gate latch
Remove the gate, unscrew the hinge, replace all.
How do i replace lift gate motor on 2008 nissan quest
It is hidden behind the side panels. You have to remove the rear seats. The panels mostly just pop off. But remove the access panels to find hidden screws. When pull the panel/s, if they don't want to come off with force, mostly there is a screw close by.
GMC Acadia Power Lift Gate Not Working
Will require a scan tool to check for codes, make sure latch is working well, make sure release switch is getting signal. Most common concern is the latch itself though
2helpful
How do I fix the liftgate sensor on a 2005 nissan quest
I purchased a 2005 Quest that had same damage on the rear lift gate. If I crossed my eyes and pressed down on the magic spot 3% of the time I could get the door to close in a way the sensor would recognize so I didn't have the door open light turn on.
Too fix this problem I removed the interior panel from the lift gate which allows access to the the lock and some of the wires. almost directly behind the licence plate you have access to the inside the lift gate you should see 2 wires that appear to be going down the latch. I'm assuming one of these controls the power locks and the other is for the feedback sensor that tells the car the door is open.
on the drivers side of the opening that exposes the wires going down to the lock you will see there is a white connection for 1 of the 2 wires that is mounted to the inside of the lift-gate. All I did was squeeze and separate this connection and the car no longer recognizes the door is open.
I don't have an alarm so I don't know if this would mess up the alarm other than if someone broke in through the lift gate it wouldn't trigger the sensor.
I hope this helps
1helpful
2008 Nissan Quest Reverse Park aid stoped working. First sound got funny and then quit. The switch disable light stays on and won't turn back on
replace the beeper that makes the sound when you are in reverse.the light will also go out after you replace thet beeper.
2helpful
Automatic liftgate won't open
The lift gate motor needs to be replaced. Preferably at the dealer ship. Its a pain to replace and most shops will do shoddy work and destroy your interior when doing it.
2005 Nissan Quest Automatic Liftgate won't open.
More than likely the lift gate motor has failed.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
