Question about Samsung HT-DB600 System
Rolling screen when playing DVD
When you play the DVD player, the picture repeatedly rolls up the screen, like an old time TV that needs it's setting adjusted, or an old time VCR that needs it's tracking adjusted.
  • 147 Answers
SOURCE: dvd's repeatedly freeze and stop playing
Your dvd drive needs cleaning of its lens. just open it and clean it with a soft cotton .
The problem will get rectified.
Posted on Jun 25, 2009
0 characters
1 Points
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Home Theater Systems
When I hook the HDMI cable to the tv and put the dvd player on the setting for 1080p I get no picture but when I put it on 480p it works fine. What do I need to do to make the dvd player to play the 1080p?
you can only upscale through a good amp.set the dvd player to old is the tv?are you playing a new release?is the HDMI cable compatible with 1080 1.3b?
Jul 11, 2010 | JVC TH-G30 Theater System
Picture rolls on DVD
Maybe your input cable isnt put in all the way from your dvd player to your tv or reiceiver
Nov 03, 2008 | Bose 3 2 1 GSX System
Green line on TV with DVD playing
The aspect ratio is fine, I just fixed mine you have to use the TV remote, and press the left or right directional button depending on where the green line. Philips TV offsets the picture when using HDMI, but its easily fixable using this remedy. Time to take the tape off haha!
Mar 07, 2008 | Philips HTS-6500/37 System
Horizontal rolling solution need more info
rolling in the sense? what you mean?
Feb 08, 2008 | Koss KS3161 System
Koss KS5190 Display mode stuck
I'm not ranked and I'm not a Guru, but I can solve this picture rolling when the problem is "the video was accidently changed from NTSC to PAL and you can't see what your doing to get it back". You will need the remote control unit. First, remove the disc from the tray. Now, turn the unit off with the power button. The tray will close by itself. After the display on the front of the unit goes out, turn the unit back on using the remote control. This will let you know the remote control unit is working. When the power comes back on and the display on the front of the DVD player says, "NO DISC", with the remote control and (very important) while pointing the remote at the player, (Remember to point the remote before pressing any buttons) press the "Down Arrow" button 3 times. This will take you to the "Display" box. Now, press the "Right Arrow" button 1 time. This will take you to the "TV Image"box. Now, press the "Down Arrow" 1 time, this will take you to the "PAL/NTSC" box. If you have done everything as I have tried to clearly lead you blindly to your destination. Press the "OK" button 1 time and the picture on the screen will stop rolling and change from black & white to color. You will have now changed your video output from PAL to NTSC. If you press "OK" again, it will start to roll again. If this did not take care of your problem, turn the player off and try it again.
The previous problem solvers were on the right track, but the track was rough and they just about derailed the train. Thanks to them, I had a track to follow. I had no other information, except what I found on "". MR. CD
Feb 03, 2007 | Koss KS5190 System
Picture rolling when I play DVDs
I used to have that same problem with my system. Fortunately for me, I still had the instruction booklets at the time so that helped me to figure it out. step 1: make sure there is no dvd in the dvd player before you start fixing the problem. Step 2: Press the "setup" button on the remote. Step 3: Once you have removed the dvd from the dvd player it should allow you to go to "preferences" in the setup menu. So do that. Step 4: Go to "TV TYPE" and make sure it's on NTSC. And then exit setup by pressing the setup button once again. And it should work. That's how it worked with my system at least. It seemed to switch the tv type by itself from NTSC to PAL which must be a flaw in the system. I thought I was the only one with that problem. Well, I hope that helped you at all. Have a good day.
Jan 12, 2007 | Koss KS3161 System
Akai DHT300 screen rolling
The picture is rolling because there is no sync signal in the composite output. Are you using the RCA jack or the S-video output? Is there another small TV you could hook up for a test to see if the problem appears there? If it does, then the Akai has the issue and needs to be examined further. If not, the TV input may have an issue. You didn't say what the TV is but there is the possibility the video input is looking for external sync from the DVD but that's a bit of a stretch. Can you feed a different source into the video input of the TV to see if you get the same result? Hope this helps.
Nov 01, 2006 | Akai DHT300 System
Problem with original dvd
Before performing any operations, make sure of the following: ? Check the connection with the TV. ? Turn on the TV and select the correct input on the TV to view the pictures or on-screen indications on the TV screen. ? For DVD playback, you can change the Setup menu setting to your preference menu... Alos, make sure thay the system and disc region code numbers are incompatible: The following discs cannot be played back: ? DVD-Audio, DVD-ROM, DVD-RAM, DVD-R, DVD-RW, CD-ROM, CD-I, (CD-I Ready), Photo CD, etc. Playing back these discs will generate noise and damage the speakers. * Note on Region Code DVD players and DVD Video discs have their own Region Code numbers. This system can play back DVD discs recorded with the color system of NTSC and PAL whose Region Code numbers include ?3.?
Dec 15, 2005 | JVC TH-A5 System
Samsung HT-DB600 System Logo
29 people viewed this question
Top Samsung Home Theater Systems Experts
Electro Med Services...
Are you a Samsung Home Theater System Expert? Answer questions, earn points and help others
