To
troubleshoot the issue, click the link below:
Car Repair Diagram
http://technoanswers.blogspot.com/2013/03/car-repair-diagram.html
HOT/WARM START ISSUE
Its
a hot start issue.
Can
be related to low fuel pressure or problem with crank sensor.
Also
it can be weak battery or starter.
But
possibilities are to be inspected to confirm what exactly it is.------
To
troubleshoot and confirm the issue,i suggest you refer few solved help links
with similar types of problem like yours:------
Click
the link below:------
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These
details will help.
Thanks.
HEATER NOT
BLOWING COLD,NO HOT AIR FROM HEATER,A/C BLOWS HOT AIR,A/C NOT BLOWING COLD,
COLD AIR FROM HEATER,BLEND DOOR ACUTATOR CLOSED,HVAC UNIT NOT OPERATING,
http://alltypesofpartsreplacing.blogspot.com/2012/12/heater-not-blowing-coldno-hot-air-from.html
Its
a hot start issue.
Can
Also
But
To
Click
These
details will help.
Thanks.
For car running hot and overheating issues, I suggest to you go
through this help links. Click this link below and go through the
troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and
troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
blowing cold?
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
troubleshooting?
For car running hot and overheating issues,i suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems :----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
