Question about Lands Phones
PANASONIC AUTOLOGIX EASAPHONE ANSWERING MACHINE
IT LOOKS LIKE IT IS WORKING FINE BUT IT DOES NOT START AFTER 5 RINGS. WHAT´S WRONG?
  • Anonymous Aug 10, 2008
    The answering machine will not answer after 4 rings.
The message answering button on my Panasonic KG-TG6702 telephone gets turned off when I try to listen to the messages remotely. Any ideas to fix this?
Thanks,
Frustrated
Posted on Jul 30, 2009
SOURCE:
Why is answering machine volume too low?
Panasonic Cordless Phone - quiet volume - Phones - Gadgets - Whirlpool
forums.whirlpool.net.au > Gadgets > Phones
WhirlpoolJan 4, 2011 - We've just got a Panasonic KX-TG4393 Cordless phone ...objectID=4555), but the volume is extremely low and it's very. ... have a problem hearing messages on the answering machine. ... Looking for any suggestions too.
Panasonic Dect 6.0 4-Handset Cordless Phone with ...
www.amazon.com/Panasonic...Answering.../B001RTU...
Amazon.com, Inc.Panasonic Dect 6.0 4-Handset Cordless Phone with Answering Machine .... I do not mind the low ring volume because too loud rings bother me but I am listing ...
Panasonic KX-TG6445T DECT 6.0 Cordless Phone with ...
www.amazon.com/Panasonic...Answering.../B001P80...
Amazon.com, I
Jan 07, 2016 | Panasonic Lands Phones
Setting the number of rings before answering machine kicks in
Here is the link to the user manual; http://service.us.panasonic.com/OPERMANPDF/KXTC1501B.PDF Check page 19 - you can set the answer rings from 2 to 7 Hope this helps :)
Jun 19, 2007 | Panasonic KX TC1501 Cordless Phone
IS THE PANASONIC EASAPHONE KXT 2395 A DIGITAL PHONE?
It is an analog phone with some (digital) electronic circuitry for extra functions such as redialling.
Therefore I would answer: no.
May 10, 2014 | Panasonic Easa-phone model Kx-t2395
I have a panasonic KX-TGA410C phone and would like to change the number of rings before answering machine comes on.
it's so easy friend just dial *94 and hit 4 or 5 or 6 upto 10 ring numbers
for example *948 dail... will give u 8 ring count before voicemail start
good luck
Dec 18, 2012 | Panasonic Lands Phones
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
Won't answer and won't dial.
Use a plan phone to test first before attaching it to fax....
Mar 13, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Nov 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Fax answer machine
FAX RECEPTION THROUGH AN ANSWERING MACHINE:
This mode is recommended for a shared fax and telephone line.
To receive a fax if your All-In-One is connected to an answering machine:
On the control panel, press Fax.
Set the answering machine to answer incoming calls before the All-In-One does. For example, if you have set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
To change this setting on the All-In-One:
Press Options until Number of rings appears.
Press the right arrow (+) until After 5 rings appears.
Press Select.
Make sure the Auto Answer light on the All-In-One is on. When a ring is detected, the answering machine picks up the call.
If a fax is detected, the All-In-One receives the fax, and disconnects the answering machine.
If a fax is not detected, the answering machine completes the call.
Feb 18, 2008 | Lexmark X4270 All-In-One InkJet Printer
Panafax UF6000 answers during voice call
You may want to look and find out if the machine has a fax priority setting. That means that at anytime a fax is received it will terminate the call and answer the fax.
It is a " feature" as some call it. On some fax machines it can be turned on or off. On some, its just on all the time.
Feb 16, 2008 | Panasonic PANAFAX UF-6000 Fax
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Lands Phones Logo
100 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
