None
There is a lot of things that can cause this problem. Some are... Timing belt has jumped a tooth or so, lack of oil, Worn engine valve train components like worn cam shaft, worn lifters, collapsed lifters, also incorrect cam shaft timing, worn timing chain (if equipped) incorrect ignition timing, incorrect injector timing. You get the idea.
Change your oil now and once you take off the oil filter look for metal shavings if there are take it to a trusted mechanic asap
SOURCE: ThenI start my engine it sounds like diesel and no power
how is the oil level and pressure?, how many miles on engine? is this a loud knock or rather a clatter/ticking noise? knock is engine rod or crankshaft bearings, clatter loud ticking is valve follower noise. how long before it (the noise) goes away?
SOURCE: Seat Leon 2007 FSI - where is the OBD2 socket
Look under the drivers side of the dash sometimes they're tucked away.
SOURCE: seat leon 20v
Is the accu still right? (12V round about)
Are the bobines and the bougies still alive?
Check the connectors from both, they are up ( 4 in a row )
(first time i looked here, could be that your problem is already solved by now)
SOURCE: jeepmanual
Grand Cherokee 2001 - 2004 also called WJ Model, in this link ypu can find several docs about this great vehicle: Jeep WJ Repair Manual
Good luck!!!
SOURCE: dasboard lights flash and warning beep operates (Seat Leon 2001)
flashing dashboard lights when the ignition is turned off
