New springs are installed on cross shaft. suspension bolts are installed. how do I get spring to fit on front slider?
Lexus Car ES, IS, LS 1998-06
Coil Spring Rear Suspension
Hub & Bearings
Adjustment
Check the backlash in bearing shaft direction and the axle hub deviation. Maximum for backlash should be 0.0020 in. (0.05mm) and for axle hub deviation 0.020 in. (0.05mm).
Fig. Checking wheel bearings for excessive play
NOTE
The rear wheel bearings are non-adjustable. If the wheel bearing is out of specifications, replace the wheel bearing.
Removal & Installation
Fig. Removing the oil seal (inner)-LS 430
Fig. Removing the axle hub from the axle carrier-LS 430
Backing plate.
Inner race (outside) from the axle hub
Fig. Removing the inner race (outside) from the axle hub-LS 430
Oil seal (outer) from the axle
Fig. Removing the oil seal (outer)-LS 430
Snapring from inside the axle housing
Bearing from the axle housing
Fig. Installing the oil seal (outer)-LS 430
Backing plate to the axle housing. Do NOT install the bolts or nuts at this time.
Inner race (inside) to the axle housing
Axle hub to the axle housing
Backing plate in position. Tighten the bolts and nuts to 43 ft. lbs. (59 Nm).
New oil seal (inner) to the axle housing. Coat the oil seal lip with multipurpose grease.
Fig. Installing the oil seal (inner)-LS 430
New dust deflector. Be sure to align the hose for the ABS speed sensor in the dust deflector and axle carrier.
Upper control arm to the axle carrier by installing the nut. Tighten the nut to 80 ft. lbs. (108 Nm).
Axle carrier and upper control arm to the vehicle as an assembly
2 upper control arm set bolts and tighten the bolts to 121 ft. lbs. (164 Nm)
Bolt and nut holding the strut to the axle carrier. Tighten to 101 ft. lbs. (137 Nm).
Bolt and nut connecting the No. 2 lower control arm to the axle carrier. Tighten the bolt to 60 ft. lbs. (81 Nm).
Nut and adjusting cam to hold the No. 2 lower control arm to the body. Align the adjusting cam marks and tighten the nut to 57 ft. lbs. (78 Nm).
Stabilizer bar link to the No. 2 lower control arm and tighten the nut to 48 ft. lbs. (65 Nm)
No. 1 lower control arm to the axle carrier and body. Install the nut to hold the No. 1 lower control arm to the axle carrier. Tighten the nut to 43 ft. lbs. (59 Nm).
Nut and adjusting cam to hold the No. 1 lower control arm to the body. Align the matchmarks and tighten the nut to 57 ft. lbs. (78 Nm).
Strut rod to the axle carrier and body. Install the bolt and nut to hold the strut rod to the body. Tighten to 57 ft. lbs. (78 Nm).
Bolt and nut to hold the strut rod to the axle carrier. Tighten to 136 ft. lbs. (184 Nm)
Parking brake shoes and cable
Outboard joint side of the halfshaft and align the matchmarks on the side gear shaft and the halfshaft. Coat the threads with clean oil and install the hexagon bolts. Tighten bolts to 61 ft. lbs. (83 Nm).
Suspension member brace with the 2 bolts. Tighten the 2 bolts to 37 ft. lbs. (50 Nm).
Nut to hold the halfshaft to the rear axle. Tighten the nut to 213 ft. lbs. (289 Nm).
Lock cap and cotter pin
Brake disc to the axle hub with the matchmarks aligned. Install the 2 screws and tighten the screws to 48 inch lbs. (5 Nm).
Brake caliper to the vehicle and install the 2 bolts. Tighten the bolts to 77 ft. lbs. (104 Nm).
ABS speed sensor and wiring harness
Height control sensor link with the matchmarks aligned. Tighten the nut to 48 inch lbs. (5 Nm).
Rear wheel(s)
Negative battery cable
Fig. Exploded view rear carrier assembly, hub and bearing-
Fig. Exploded view rear Axle carrier and hub assembly-ES 330
Stabilizer Bar
Strut & Coil Spring
Fig. 6: Oil pan mounting bolt locations-1996 3.1L engine shown
Fig. 7: Oil pan sealant application points-1996 3.1L engine shown
Adjustment
NOTE
The following procedure may be used to remove shoes on either side of the vehicle.
Fig. View of the actuator (1), support (2), adjuster spring (3), return spring (4), caliper adapter (5), shoes (6), hold-down clips and pins (7) and adjuster (8)
Adjustment
This vehicle is equipped with permanently sealed rear wheel bearings. There is no periodic lubrication or maintenance recommended for these units.
Fig. Hub assembly
Fig. Rear hub and bearing mounting bolts
