Screen fades to dark help support forum
SOURCE: screen goes dark
Either the backlight lamp or the invertor for it is failing. I suspect the colors and contrast isn't as it once was either.
SOURCE: Toshiba Satellite a45-s130 screen has gone real dark need a flash
Paul, Georgiana and You, 1. do you have an antivirus installed on your laptop? if not, then install one rightaway. 2. also from start->control panel->system->hardware->display adapters and monitor. uninstall the display adapters and reinstall them. similarly uninstall and reinstall the monitor drivers. 3. go to http://www.drivershq.com/Drivers/Toshiba/Satellite/A45-S130/4183/9941/10606/Drivers.aspx you will find here a driver detective that can detect your driver problems. try with that. 4. on the site above you will find drivers, for you to download and install on your laptop. if you still have problems, then you have
SOURCE: Toshiba Satellite 105A screen too dark to see password box
have you tried the F5 key?
On a lot of laptops that toggles the video output between the laptop display and the external display connection (socket on rear of laptop).
Cheers,
Steve
SOURCE: Have a Toshiba Satellite laptop M105. The screen
either the the invertor or the screen is faulty and will need to be replaced.
