SOURCE: error code C0F37 on Kyocera mita KM-C1530
This code is not documented, the firmware must be reloaded and a service tech can only do it ...
SOURCE: kyocera colour copier how to get the machine mod
r u sure it is kmc 2350,i just looked there dont seam to be such model??
SOURCE: kyocera 5050 error code 2202
This is an error is indicating a connection error when using the send feature. 2101, 2102, 2103, 2201, 2202, 2203, 3101: The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name correctly. 2204: The E-mail size exceeds the acceptable send data capacity. Decrease the size or resolution of the scanned data to be transmitted and resend the E-mail. 5101, 5102, 5103, 5104, 7102, 720f: Turn the main power switch off and back on. If this error occurs several times, make a note of the displayed error code and contact your service representative.(Refer to the corrective action for the error message " An error has occurred.") 9181: The scanned original exceeds the acceptable number of pages of 999. Send the ecess pages separately. Hope this is helpful, Shawn
Below I have provided some information or for more information download the users guide from the manufatcures website using this link. http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=16088&rid=16313
SOURCE: Error Code C 7460 On Kyocera Taskalfa 8000i
Developer shutter locked - open front cover and slide the developer shutter to open/unlock, restart the machine. The shutter is locked to prevent developer spilling when transporting the machine.
SOURCE: Kyocera km 4050 showing error code cfb31 how to clear it
hello,
This error has to connect the connector (red, green, white, black, black) in the wrong place in panel. yc1 - yc9
