SOURCE: Jeep Liberty Left Rear Turn Signal Not Working
sounds like the bulb you have is the wrong resistance the new noen bulbs will do this
SOURCE: 1993 Dodge Shadow...left turn signal won't flash
If you have trouble finding signal flasher, turn your right side blinker on, and follow clicking noise to flasher.
SOURCE: My 1999 Dodge Grand Caravan left rear powered vent isn't working.
IF YOUR TALKING ABOUT THE POWER VENT WINDOW.IT MAY BE HYPER EXTENDED LIKE A KNEE OR ELBOW.TRY TAKING A SCREWDRIVER FROM THE OUTSIDE AND PUSHING THE HINGE INWARD JUST ENOUGH TO LET THE MOTOR WORK IT CLOSED.IF THE MOTOR ITSELF ISN'T WORKING PUSH THE HINGE JUST PAST CENTER THEN USE YOUR HAND TO CLOSE THE WINDOW PUSHING IT CLOSED WERE THE MOUNT IS UNTIL YOU CAN GET A NEW MOTOR.HOPE THIS HELPS
SOURCE: Brake light, reverse light and turn signal issues
Hello. The symptoms you are describing are likely due to a poor ground. Temporarily install a new ground wire by securing a piece of copper wire to the frame with a self tapping screw. Use this ground wire along with the hot wire to see if each of these lights works. If it does, trace the ground wire back to the frame, unscrew it and clean up the metal with emery cloth so you reestablish a good ground.
