Dear, there has been different models of several vendors and its installation and procedures are also different. But, I guide you that is very same in many faxing that first put or fix a roll or some papers, then you should check a copy for output or input. When you adjust a paper then you type a number and wait for negotiation after the ring. When negotiation will start you press the butten for OK. This fax will out and now you will receive a paper of confirmation.
I hope your problem will solve.
Thanks
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple...
(More)
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple of days ago. Test pages print fine from the print controller.
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has...
(More)
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has never been used for scanning
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink....
(More)
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink. How can I select "print in black only?"
