Cars & Trucks Logo
E
Eileen wilkins Posted on Dec 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can somebody please where the switch is on a elddis caravan to change the water heater heating to gas. ThNkyou
We bought the caravan but don't have any instructions with it ' We would appreciate a reply.
David Harrelson
Level 3:
  • Cars & Trucks Master 5,456 Answers
  • Posted on Dec 17, 2014
David Harrelson
Level 3:
Answers
5456
Questions
17
Helped
1101751
Points
15442
Many do not have electric heating elements, but if yours does, it should only work when plugged into "shore" current. Without that hooked up, unit should try to light and run on propane automatically when you turn on switch. If it does not, igniter may be bad. Time for a trip to camping world pro.
Why do I only get heat through my vents when I'm driving?
if fan not blowing check fuse relay --if good check control -switch -regulator -fan
1999 Dodge Grand Caravan heat is cold
There are two possibilities, one is the thermostat. Many people remove them which spoils the whole heating / cooling system. Since you changed the thermostat, I would check the heater valve on the heater which allows the hot water to circulate through the heating system.
It may be necessary to remove the heater box and flush the heater core since you talk about a lot of rust, which could have clogged the heater core and / or the pipes leading to the heater.
Heater control panel lights come on don't blow heat
have encountered this before turned out to be faulty thermostat and faulty thermostat switch
There is no heat in the rear, im thinking its a problem with the back heating core. I have a Dodge Caravan 2001. Whats wrong and how can i fix it?
There should be a vacuum control switch in the heater line going to the heater core that may not be working.
it shuts the water off to the heater core and when heater is turned on the vacuum switch opens the door inside of switch to allow the water to go to the heater core.
1helpful
98 dodge caravan wont switch over from cold to hot on the heater controls
Most cars have a cable operated switch under the hood which allows hot coolant to flow into the heater core when the switch is activated. This switch is usually located close to the firewall behind the engine. Look for coolant hoses running to it.
Have someone inside the car change the heater control to heat while you watch the switch. If it's operating correctly, you should be able to see the movement. If this switch does not move, hot coolant is not entering the heater; and you will not get any heat.
I have a 1995 dodge caravan and im trying to locate the air valve that contols the amount of heat for the heater?i have hot water going in and out of the heater core but my heat on the inside is luke warm...
240cpa is right.dodge caravan does not have a heater control
valve and coolant constantly crculate in heater core . use the temperature contorol on instrument panel if you notice no change in heat your blend door in heater box is not moving . and as 240cpa mentioned make sure the t stat is not stuck open.
1helpful
3answers
Heater fan regulation
2002 Grand Caravan. The rear heater also has a resistor for the fan speed control.(3 speed) It is located under the rear passenger side plastic cover. You can take off the rear tail gate lower plastic piece and this will let you pull out the side panel. You can reach in and take out the two screws that hold in the resistor and unhook the wiring adapter. You do not have to take off the whole side panel as you can reach in from the back. The resistor unit can be bought at you local dodge dealer.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
