Question about Alpine CDA-7840
Alpine CDA-7840 works but does not light up for about half an hour
I have this head unit it has the black out feature (which i am not sure what use it is) I turn the vehicle on and everything works i just cant tell what station I am listening to or what track on the disc I am on its completely blacked out after a while (half hour sometimes longer) it will light up perfect. I have tried cleaning the connections between the face and unit no luck there any suggestion would be great thanks
  • evan907 Mar 12, 2009
    I have the same problem, it has worked once on it
I have the exact same problem and it has been driving me nuts for several years now.  I have tried everything with no luck.  I finally resorted to buying a used faceplate on eBay (and they had several available so I suspect this is a common problem).  I will let you know how it turns out.
Posted on Feb 09, 2008
I hav a alpine cda-w925ehi head unit an it just stopped an now says "interrupt"
Hi I believe you have an Australia model? Alpine's use what's know as an interrupt wire to hook into vehicles/phones to interrupt the audio of the deck when their is a signal sent to it. On the Alpine harness you need to search for the Pink/black striped wire which is the audio interrupt wire. Make sure that wire is insulated and not grounding out against anything or hooked up incorrectly.
Nov 28, 2012 | Car Audio & Video
Replace my citreon c4 head unit
what year is your car?newer cars 1999 and up the radio wiring harness goes thru the ecm (electronic control module).if that head unit is not supported it wont work a bad case senario the head unit could damage the ecm.
Nov 03, 2007 | Alpine CDA-9847 CD Player
No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Dec 12, 2008 | Alpine CDA-9855 CD Player
Alpine cda-w550e
It must be an older unit, because it is not on the Alpine website call Alpine and they will help get you a manual. 1-800-421-2284 Ext.8853
Aug 26, 2008 | Alpine CDA-7998 CD Player
Alpine cda-w550e manual
I needed a manua for my alpine cda-7897 and went to alpine's website and just type in my unit number under there manual section and there it was in a nice little pdf. file. hopes this helps.
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Jul 23, 2008 | Alpine CDA-9805 CD Player
Alpine CDA-9805 head unit - frequency hops
make sure no switches are jammed on radio or radio face.Liquid spillage and or intermittent switches on tunning section can also cause this.
Nov 29, 2007 | Alpine CDA-9805 CD Player
Alpine CDA-7840
Some 4-Runners have a factory system that uses a separate amplifier to power the rear speakers. In this case you need to activate the amplifier using the blue/white remote output from your Alpine deck. It sounds like the wire that activates the amplifier is currently attached to the deck's blue "power antenna" output, so that the amplifier is only on when the tuner is selected. Disconnect whatever is attached to the blue wire behind the deck, and attach it to the blue/white wire instead. That should solve the problem.
Jun 09, 2007 | Alpine CDA-7840
Alpine head unit CDA-9855R
Yes, I'm sure Alpine will sell you another face but there is still the option of repairing the broken face at a good repair shop. Of course getting a new face is the easiest (read most expensive) way to get you going again.
Jun 08, 2007 | Alpine CDA-9855 CD Player
Car Audio & Video Logo
204 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
