Just gently pressing into position
Thank you for your inquiry, cheryl!
I understand that you have removed your soap dispenser on your Electrolux washer and are having a challenge getting it back into place. It should go back into place once lined up. If you continue you having an issue I would suggest having a professional technician out to your home for proper install of the dispenser. Good luck. -Matt
SOURCE: MY FRONT LOADING FRONT LOADING
You can refer to the link below on where you could seek assistance from the following dealers in GOA
SOURCE: Electrolux front load washer door won't
First try to reset the lock unplugged the power machine for a few (10) minutes (maybe release the interlock door switch). If this work, them its possible that you need door latch replacement.
To do it, turn
off power, unplug at the mains. Drag the machine out so you can see
the back. Remove the 2 screws that hold the top on, pull back or tap
the top forward (depending on the model) to unclip it. Peer inside.
You will see the door switch inside the chassis exactly in line with the
door handle on the outside. See if you manually make the mechanism
release, or if you have a stubby philips screwdriver, you can probably
unscrew the switch complely.
Keep us updated.
