The antenna screws into the radio; but the screw base appears to be stripped. A crew member accidentally bent the antenna too far and it ripped out of the socket. I need to have the radio repaired.
To be honest with the current cost of the radio it would be cheaper to buy a replacement or go to Uniden's web site and check a factory outlet store like the one here Uniden 2 Way Radios Two Way Walkie Talkie Radios Marine Radios CB Radios... and purchase one rather than pay to have it fixed.
If only the base is stripped and it is just a short "standoff" or a "nut" like threaded post riveted to the pc board, I would go find a plated brass nut or standoff an just solder it on top of the one that's there. If the base of the antenna is stripped, too, there should be an inexpensive replacement antenna online.
SOURCE: Replacement parts
Hello daemon10,
The current trend is for manufacturers to bundle consumer two-way radios in packs of two and four since most users do not purchase single radios. However, some models are available as single units and any 22 channel FRS/GMRS combo radio should be able to communicate with your Uniden radio.
If you definitely want to get the exact same model you might have to either purchase another two-pack or contact the manufacturer directly to see if they have single units available
Best Regards,
Agent Ken
Go Ahead. Use Us.
SOURCE: need a new uniden hh985
Regards,
Tony
SOURCE: trying to damaged/broken antenna on
The antenna just is screwed on. It is tight becaust they use locktight on the threads. You might need to use some plires to remove the antenna. Do not use to much force though to unscrew it. There is no set screw in the holes the holes are there for there tool that they use to install the antenna.
