Replaced the transformer, circuit board, and motor assembly
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Testimonial: "I really appreciate the response, I have checked the position of the dip switches before and found them to be at the setting in the manual. I will check them again. I keep looking at the inductor which looks like a transformer. I have no idea what it does but it seems the power surge I experienced affected transformers more than anything, any thoughts on that? Is there a way to test it?"
Really appreciate the response, I've checked the dip switches before and found them to be in the correct position
