Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Jvc 56wp74 convergence worse after ic's replaced help
Hi, i have the 56wp74, red was out of wack, i properly installed new ic's, and now the green is curved, the red and blue is out of wack too. i tried to manually adjust in the service screen, without luck. i tested all the resistors, and the only two that dont seem right are the 220 ohm on the r873 spot on the board, and the 150 ohm resistor on the r863 spot. both read 89ohms instead of what is on the resistor. could that be the problem, and where can i get thoes resistorsts, and what is the actual name/model of thoes resistors so i can order them ? thanks
    Problem Solver:
  • 3 Answers
I had the same problem, the R873 and the R863 are hooked up in parallel or something. I test themboth on mine and they were measuring 89ohms each and I could see that they were parallel, and that means they should be the average of the two, so I cut them out. I measured them after I cut them out to see which was the bad one, and the r873 measured 220 ohms and r863 measured 150ohms, both exactly correct. Not sure what the deal was. I have since been trying to find replacements... Who knew. Good luck!
Posted on Nov 12, 2008
Originals were stk392-110 with b3f11 in the top right corner, sanyo i believe, and the replacements are stk392-110 with d5l13 in the top right corner. they are genuine sanyo replacements as them from ebay daler: active parts auction number:160113543774 it is still available to see. thanks
Posted on Nov 22, 2007
  • 1,694 Answers
I can research for you....Please tell me...what are the IC #'s ,
original and replacement, OEM quality or generic,from what
I have a green line converge issue i can't get it to line up, i get it close then th red line moves out of wack. The right side of the picture starts to look 3D. What can I do
Convergence issue, if you cannot fix it by convergence adjustment, is un-doubtedly due to malfunctioning STK amplifier ICs. There are two of them that need to be replaced . They are located behind large aluminium heatsinks as shown in the image below.
The ICs can be purchased on ebay by using the IC numbers in your set as search keyword. You will have de-solder the old ones, apply silicon based thermal grease to the replacements and solder them into the board. Note that you have to make sure that they are making good contact with the heatsink when you replace them. You will also need to test and replace any resistors that the ICs may have taken out when they have gone bad. I hope you know how to use a multimeter(or ohm-meter) and can read resistor color codes. color code chart/Live4soccer7/360fullres/resistor_color_code_chart.jpg
If there is any thing else you would like to know, please let me know.
PS: Bad rating = No further help
Sep 16, 2011 | JVC AV-56WP74 56" Rear Projection...
I have a jvc av56wp74 double immages in red and
Ur tv have convergence problems,it dead.U must have soldering tools and know how to solders to fix the convergence problems.U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair, to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 05, 2010 | JVC AV-56WP74 56" Rear Projection...
Convergence problem
Did you lock the adjustment into the TV's memory? This step is the most often missed. Please follow the directions on the Users manual or on the service manual on how to set your memory to hold the configuration.
Find the menu item on setting the convergence adjustment into memory (the menu should have an informational screen on this topic)
I hope this helps
Thank you,
Mar 06, 2009 | JVC AV-56WP74 56" Rear Projection...
Jvc 56wp74
sounds like a solder related issue on the convergence ICs. They are acessed through the front of the TV behind the speaker grille and then remove the small acess panel and you will see the convergence amp board with the two ICs on it.
Oct 26, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC I'Art AV-56wp74
A repair facility will charge 400 to 600.00 for the repair. Or you can repair it yourself if you can solder. As both convergence ICs need to be replaced. They are STK392-110 you can get replacement ICs at the following link with free instalation instructions with pictures so you can do the repair yourself. Heres the link.
Jun 15, 2008 | JVC AV-56WP74 56" Rear Projection...
Red - green and blue seperation after a storm
The convergence Issue is caused by your convergence ICs needing replacement you will need to replace both convergence ICs they are STK392-110 and you can get replacements at the following link and they provide free instalation instructions with the ICs and if you leave them an email indivating the problem with your remote and your model number they will also have the small sensor that your TV needs and they can tell you how to test wether the remote is at fault or if its the sensor itself that you need.Heres the link.
Jun 14, 2008 | JVC AV-56WP74 56" Rear Projection...
Help with jvc projection
you will need toreplace both convergence Ics they are STK392-110 ICs you can get replacement ICs at the following link with instalation instructions.
Jun 07, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc pos
when in manual convergence hit the select bottom to change to blue. as of green i have no clue.
Apr 17, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC projection tv
Mike, convergence adjustments are in your menu, usually under "video" settings. You have to adjust red & blue onto the green, when you`ve done it correctly the "cross" will be pure white, if you cannot move either of the colors left, right, & up, down then the convergence IC`s have failed and will have to be replaced, hope this answers your question, BMW Rider
Dec 30, 2007 | JVC AV-56WP74 56" Rear Projection...
Double vision On JVC AV-56WP74 56
You have an convergence problem, There are 2 IC's that go bad and a few resisters that can change value. If you flip the board with the Chips inspect the pins for cold solder joints. The IC's can be purchased from matelectronics
Jun 17, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
177 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
