I deleted files in temp,%temp%,prefetch folders.This is not enough to make PC fast.Now what should I do? Is there any such kind of software to clean up the disk?
First go to https://www.Piriform.com and download the free version of CCleaner. Install it and run it. However you must first go through their list of cookies and protect the ones that you want saved. You'll have to do that for about a week.
Then go to the following site: https://ninite.com. Use it to download Malwarebytes Anti-Malware (the free version)and run it and. SUPERAntispyware (the free version), but be sure to click on only one of them before you click on the big green rectangle. Then don't install it, but uncheck the first one, check the second one and click on the big green rectangle. You will now have two files that look like this: Ninite "the program name).exe. Then double-click on one of them and let it run, thus installing the program while Ninite makes sure that no malware is installed. Then do the same for the other. Then run these programs. These will help you check to see if you have an infection of malware of any type. Next go to https://www.bleepingcomputer, download Rkill and jrt. When you try to download jrt you will be given a choice of using the Bleeping computer site or the "authors site". It doesn't matter which of them you use. Note: these program do not need to be installed - just run them. First run Rkill. Then run jrt which function at the DOS level. This is a slow program but an extremely efficient one. jrt stands for Junkware Removal Tool.
Next go back to Ninite and download Glary and have Ninite install it for you. Don't let them touch your registry, but have them clean your Hard Drive.
That should do it for you. Note - keep the Ninite installation files in their own folder. Ninite knows when an update occurs and if once a week you double-click on each of them it will install the update safely or tell you that you still have the current file.
Thought, XP Pro is now unsupported. There is probably an XP Pro forum on the Internet where you can ask questions. Still I would seriously consider updating to Windows 7 (if possible).
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
this should speed up your computer
hope this helps
By following a few simple guidelines, you can maintain your computer and keep it running smoothly. This article discusses how to use the tools available in Windows 7, Vista, and http://www.microsoft.com/atwork/maintenance/speed.aspx#">XP Service Pack 3 (SP3) to more efficiently maintain your computer and safeguard your privacy when you're online.
1. Free up disk spaceThe Disk Cleanup tool helps you free up space on your hard disk to improve the performance of your computer. The tool identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.
Use Disk Cleanup to:
Remove temporary Internet files.
Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
Empty the Recycle Bin.
Remove Windows temporary files such as error reports.
Remove optional Windows components that you don't use.
Remove installed programs that you no longer use.
Remove unused restore points and shadow copies from System Restore.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
To use Disk Cleanup
Window 7 users
Click Start, click All Programs, click Accessories, click System Tools, then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.
When Disk Cleanup has calculated how much space you can free, in the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.
