Question about Garden
HI I have an old 28 inch model went to put some new tyres on and one hub is F----- and the other is sizzed on. Can i get parts for it or do I have to give my wife the bad news and tell her she bought a lemon!
  • Eugene Rounds Dec 16, 2014
    Hi Craig Reynolds, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Hard to tell anything without the make and model numbers.
    As for removing a seized on wheel if comes to it a person that is skilled with a gas cutting torch can remove it; although, it most likely will not useable afterwords.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
You can pull the tires while its still mounted to the hub on the rider it a tuff way to do it but it can be done
Posted on Dec 17, 2014
What would be the biggest tyres you can put on 17 inch being standard suspension.
it depends on the hight of the truck for height , but when you want to put really wide tires on you can get spacers , I think the most depending on what truck you have is prob 12 in just guessing though
Jan 20, 2015 | Ford Cars & Trucks
Dimension of wheel cover
Have a look at your tyres (tires, you may be American).
You should find some numbers and letters on the sidewall which are the measurements for the tires/tyres and hub.
Usually they are like this:
195/65 R15
The number after the R is the size of the hub in inches for your tyres/tires. This is the number you need for the wheel covers.
:-) Cheers!
Oct 14, 2014 | 2003 Ford Focus
Just inflated tyres for first time since getting car & I am now getting a tyre pressure warning message that tells me that they need initialised - please help
Hi, need you put normal air in a gas station? If you did then that could be a problem. Since new cars uses nitrogen in the tires. Try that first. You need to go to the dealer for that.
Aug 08, 2014 | Air Intake Hose Citroen C3 Picasso 1 6hdi...
How put a pitbike 12inch rear wheel on
Buy a 12 Inch rear wheel with the same diameter axle as you ha e and with a centre hub that looks identical. Remove the old axle, remove chain, swap disc tyre and sprocket over then refit
Jan 21, 2014 | Pit SSR 110CC Pro Beginner Bike
I'm trying to change the ball bearings on the rear passenger tire and i can't get the brake's off they are drums and i'm not able to get that and the ball bearings that are currently there off to put the...
If you are having trouble removing the brake drum meaning it wont just slide off the hub using a rocking and pulling motion then try the following.
  1. Remove the rubber plug from the top of the support plate.
  2. Rotate the automatic shoe adjuster shoe with an upward motion using a medium sizzed flat tipped tool.
  3. Remove the bearing dust cap with a screwdriver or pry bar.
  4. Remove the cotter pin, nut retainer, nut, washer and bearing/hub assembly from the spindle.
Hope this helps.
Jan 12, 2011 | 1996 Dodge Intrepid
I brought a relaigh cordless cycle computer i think its a 12 function one for my old bike but now i want to put it on my new bike but my new bike has different wheels sized 26x1.50 but i have lost the...
26 inch wheel becomes 29 inches when you add on tyre depth ( 1.5 * 2 )
29 x Pi is 91 inches
Computer setting should be 91.2 inch or 2316 mm
Nov 29, 2010 | Cycling
17in alloys wheels makes strange sound
what design are they, two thing could be doing it, if the obviouse touching has already been investigated, one is the design, if the spokes/hub sits out further than the rim than the outer of the rim they could be catching the wind and making some freaky noises, or if the center dishes in then maybe they are "loud" tyres by that i mean do the tyres have wide grooves, directional etc, high performance tyres are in principle very noisy. hope this has been handy.
May 15, 2009 | 2003 Hyundai Santa Fe
Yamaha sr 125 how much air should i pump to rear and front tyres
Hi!
You are asking a sensible question and obviously are concerned and rightly so for your safety and others plus tyre wea.
Good on you!
However it depends on load,circumstances, conditions and the type of tyres/compound you have.
So as a rule of thumb, 28/30 front normal conditions rider only short journeys, 30/32 rear normal 2 riders +- 2psi for loads and long runs.
Hope this helps, press the Blue button please to rate my FREE! efforts, Thank You!
Paul 'W' U.K.,
Feb 13, 2009 | 2001 Yamaha SR 125
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
