Question about Flytouch 8 Superpad VIII
My flytouch 8 super pad is frozen. We can not get the touch calibration to work. None of the icons will respond to touch. Please help me!
Shutdown and stylis
How do i reboot a fly touch v10 tablet
Tony, you mean reset, Right ?
Check the attached links, to see how to reset.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to do Manual Factory Data Reset on Superpad Tablets Android 4 0
How to reset the SuperPad Flytouch 2 Google Android OS 10 inch
How to Do Manual Factory Data Reset on Flytouch Tablet The Classroom...
Superpad VI How to reset to factory defaults FlyTouch 3 Superpad 2
Mar 08, 2016 | Tablets & eReaders
How i recover my infotmic tab
Depending on which version you have please see the following notes:
How To Factory Reset/Recover the systerm On Your Tablet PC(Flytouch 2/SuperPAD 2/Infotmic tablet 2)
1. Press "Power" and "Home" button at the same time, hands off until you see the words on the screen.
2. Select:"wipe data/factory reset" with the "volume" button, and then press "menu" button.
3. Select:"Yes -- delete all user data", and press "menu" button.
4. Wait until you see" Enter erase_cache Data wipe complete" .
5. Press "reset", calibrate it and set the language.
How To Factory Reset/Recover the system On Your Tablet PC(Flytouch 3/Flytouch 4/SuperPAD 3/Infotmic 3)
1. first press the "MENU" key, keep pressing the "MENU" key while you press the "POWER" key, remove your hands when you see "recovery" from the screen.
2. Wait a few seconds until it is done. And then the system will start..
Precautions
A power failure during the firmware writing operation may disable the tablet PC.
* Use a fully charged Battery or dedicated AC Adapter for the firmware update.
* Do not shut off the power during the firmware writing operation
Feb 04, 2015 | Tablets & eReaders
Nextbook 8 SE touch screen not as sensitive, have to tap items twice
It might need calibration. There is usually a setting in the display to calibrate the screen. Follow the instructions and see if it helps.
Jan 30, 2014 | Nextbook Premium 8 Se Android
New fly touch doesnt load up past allwinner logo
Have you left it on a while, sometimes on first start it takes a while to innitiate.
Jan 28, 2014 | Wopad Flytouch XR Android 4.2 Capacitive...
Frozen screen
hold the re-set button down until the tablet shuts itself down if you have already done this and it does not work and you have had your tablet for less than a year usually the company will fix it for free or send you a new one free of charge because it is a problem with tablet not something you did.
Nov 11, 2013 | Flytouch 8 Superpad VIII
Users manual needed
Try this website: http://www.crashzilla.com/support/
The manuals for Flytouch 2 & 3 are on this page in pdf form.
Hope this is of help.
Jan 16, 2013 | Android Flytouch 3 8gb 10.1 Inch Super Pad...
Flytouch 8 Superpad VIII Logo
Top Flytouch Tablets & eReaders Experts
Are you a Flytouch Tablet and eReader Expert? Answer questions, earn points and help others
