Question about Sram 2013 X0 2x10 Speed MTB Twist Grip Shifter Set - Black/Red
Right shifter does not lock into gear. Slips back too bottom gearing. What is the fix on this
Nothing
How can i fix broken shifter on 2003 ford super Duty , automatic ? Seems like a pin broke and i cant put it into gear or out .
hey look under neath where ur driver footpedals are. chances are that the rubber grommet on the end of ur cable came off or broke.. look up into the column area an look for the black cable goin to a pivot point on shifter arm. reconnect. but will prob need new cable cause if end is no good will fall of again. move shifter back an forth to help u locate area of cable
Jun 28, 2015 | Cars & Trucks
Gear shifter is not locking in any gear. Shifting back to lowest
Most likely the little ratchet in the shifter is gummed up.
Squirt lost of WD 40 and or GT 85 in to the shifter. Blast it in to all of the nooks and crannies, kepp working the gshifter all the time.
You may need to adjust indexing.
dorkythorpy How to Stop Chain Rub Noisy Chain
Apr 19, 2015 | Cycling
Car slips out of first gear
It is possible that the shifter linkage is not aligned/adjusted properly. If not that external problem then there is an internal spring in the shifter pawl mechanism that may be broken and you if you cannot access and fix this yourself you will have to take it to a transmission shop or a Chrysler dealer to get if diagnosed and fixed.
Sep 08, 2014 | 2004 Chrysler Crossfire
Gears loose will not shift
    • 1Remove the bolts and nuts that secure the center console around the gear shifter with a 1/4-inch drive ratchet, a metric socket and a Phillips head screwdriver. This will expose the rubber boot. Pull back any carpet as needed to make room for the rubber boot to be pulled over the gear shifter.
    • 2 Turn the gear shifter knob counterclockwise to remove it from the top of the gear shifter. Pull the rubber boot over the gear shifter and place it on the floorboard.
    • Sponsored Links
    • 3 Loosen and remove the retaining bolts at the base of the gear shifter with the ratchet and a metric socket.
    • 4 Remove the gear shifter retaining ring with the pliers. Once the retaining ring is removed, you will now be able to pull the gear shifter lever straight up through the console hole. Inspect the bushing on the pivoted area at the bottom of the gear shifter lever. Remove all of the damaged bushing from the bottom of the gear shifter lever with the pliers.
    • 5 Place the new bushing over the pivotal ball end of the gear shifter lever. Hold the gear lever with one hand and twist the bushing onto the ball end with your other hand until the bushing locks in place.
    • 6 Reverse the same steps as outlined above to reinstall the gear shifter assembly and the center console assembly. Make sure that all of the retaining nuts and bolts are tight.
Read more : http://www.ehow.com/how_8389358_tighten-loose-gear-shift.html
If you need further help, reach me via phone at https://www.6ya.com/expert/cynthia_0eebb7da17b33b5e
Apr 21, 2014 | Mongoose Exile 26 Men's Full-Suspension...
Bicycle rear derailleur slips back to high gear.
It is likely that Phil has an old school Shimano Eagle rear derailleur.
I recently had a very similar issue with a Suntour friction shifter and derailleur. I tried replacing the shift cable and housing with no luck. Then I was told to replace the chain. Made no difference.
Then I took a closer look at my bike's shifter. I took my old one apart and the gear teeth that were supposed to keep the shifter from moving were worn down.
New shifter took care of it for me.
Oct 22, 2012 | Cycling
My 76 Chevy Blazer 4x4 slips out of gear. It is an automatic transmission with the floor shift for the 4x4. It will not stay in 4 high and will not work at all in 4 low. How do I fix this?
Motor and trans mounts worn or the body mounts worn letting it flex and nock it out of of Gear,,,if the truck is lifted/ or not you will need to in large the hole where the transfer case shifter comes the the floor,,,
Oct 01, 2017 | Chevrolet Cars & Trucks
Shifter slips into N when taped. Thinking the safety pin isnt locking in..
you got it in one there the gear shift is not locking in right have a look inside it it may just be a broken spring
Mar 10, 2010 | 2002 Chevrolet Tahoe
What is shift lock release, and how do I use this option???
shift lock located on your shifter by sticking a key or an small object into the hole to release the lock; Only used when need to shift out of gear if the battery is dead OR the brake sereniod switch goes bad and wont release the lock to the shifter when applying pressure to brake peddle to allow you to move shifter into gear. also state in owners manuel.
Aug 28, 2009 | 2004 Hyundai Elantra
1989 1200 Sportster frozen gear shifter
take it back as the trans and motor are one piece they did not align the innards right
Jul 05, 2009 | 2000 Harley Davidson XL 1200 S Sportster...
1995 crown vic gear problems/gear shift wont lock
if the shifter is loose and sloppy feeling then the shift cable bracket has come loose under the dash at the steering wheel. remove the lower panel under the steering wheel so you can see under the dash then get flash light and look while jiggling the shifter. you should be able to see the cable and bracket. if the bracket is loose then tighten the bolts. note this bracket is at the steering colum.
Jan 21, 2009 | 1995 Ford Crown Victoria
Sram 2013 X0 2x10 Speed MTB Twist Grip Shifter Set - Black/Red Logo
104 people viewed this question
Top Sram Cycling Experts
Michial Gueffroy
Mike
dante
Are you a Sram Cycling Expert? Answer questions, earn points and help others
